You can start it again it works the same way with E7 code
SOURCE: Pump starts and stops after few minutes
Sounds like your motor is overheating, This is a sign of windings going bad and sorry to say you will probally have to replace the motor.
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
SOURCE: four stoke mower. Mower starts and runs ok but
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
SOURCE: My matrix MX-T5x start running
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
