Question about Refrigerators
HELO PLASE TELL ME WHAT IS THE SUITABLE COMPRESSOR FOR MSD2657HEW REFRIGERATOR?
OUR COMPRESSOR REFRIGERATOR IS FAILED SO I WANT TO REPLACEMENT A NEW COMPRESSOR OLD COMPRSSOR WAS TECUMSEH BUT I FORGET THE TYPE TANKES FAHIMI
    Top Expert:
  • Refrigerators Master
  • 15,511 Answers
Look up replacement using your make and model number of fridge
Posted on May 01, 2017
aborcass
  • 2651 Answers
SOURCE: Tecumseh compressor replacement
sure there is a repacemnt compressor, problem is that youll need a technicinan to replace it for you, its one of the very few jobs that a ahomeowner would not be equipped to relaced on hter own soory
Posted on Jan 24, 2009
Buland Khan
  • 297 Answers
SOURCE: i forgeted my 3110 mobilephone security code plase.
try 0000 or 12345
Posted on Nov 19, 2009
heatman101
  • 43501 Answers
SOURCE: I think the Tecumseh compressor
Yes, this time I think your compressor is the problem. The buzzing is the compressor trying to start and because it is siezed up or the motor is not starting the windings get hot and the thermal cutout activates cutting off the power till it cools back down again.
Changing the compressor takes specialized equipment to evacuate and save the regfrigerant, change the compressor and then re-evacuate the system and recharge the unit.
Get a firm price for the whole job before you tell them to do the work. It may not be cost effective on some units to change the compressor.
I hope that this has helped you to solve you problem.
Thanks for using Fixya!
Heatman101
Posted on Nov 23, 2009
  • 819 Answers
SOURCE: Replaced the compressor in my 1999 Dodge Caravan.
the new compressor was likely shipped pre oiled. it should have had a tag on it saying if it was oiled or not, and how much. if you added more oil, the system has probably been over oiled and hydro locked. recover the refrigerant again, if you are working with an actual automotive a c machine you should be able to draw that extra oz of PAG oil out, then recharge refrigerant. hopefully that will do it! otherwise, you could have a restriction in your system, possible from debris in one of the compressors, in which case you will need to flush the lines out. good luck!
Posted on Jun 21, 2010
redneckrabbi
  • 35 Answers
SOURCE: Amana refrigerator not cooling
Fan motor locked up
Posted on May 15, 2012
Maytag mfi2568aeb
The EPA recommends keeping refrigerators at 37? F and freezers at 3? F, so your freezer temperature is obviously too high. How was it determined that the compressor was the problem rather than some related parts?
When you say, "Replaced compressor...", do you mean you did the work or had a tech do the job? Were any related parts checked/replaced, e.g., start relay?
Some repairs can be made by someone with basic electrical/mechanical skills, e.g., replacing a defrost timer or ADC.
But a refrigerator compressor should be installed by a trained and licensed appliance repair technician. This is NOT a do-it-yourself project.
A compressor replacement and charging requires specialized tools and some expert knowledge. Perhaps you have the appropriate tools, gauges and knowledge.
If a bad compressor was the original problem, and you replaced it with a new compressor (there is a chance you might have purchased a defective unit), and you have checked the related electrical parts, you may not have the correct amount or the correct refrigerant in the system. If you had a leak, the unpleasant smell might be a tell-tell sign. Check: Refrigerator Parts Compressor System Testing
May 16, 2014 | Refrigerators
Whirlpool model ed2vhgxmt00 quit cooling
Helo sir
  • Check the temperature setting
  • Make certain there is a three inch space outside of the refrigerator between the walls and the back and sides and at least a one inch gap above, to allow for air flow
  • Clean the condensor coils
  • Unplug the refrigerator, wait two hours and plug it in. If you hear it running, a problem is causing the compressor to overheat
  • Test the temperature control
  • Test the evaporator fan
  • Test the defrost timer
  • Test the compressor relay
  • Test the overload protector
  • Test the compressor motor
  • thank u
    Jul 15, 2008 | Whirlpool Refrigerators
    Tssu-36-12m-b unit no cooling
    Generally when the overload starts tripping the compressor is telling you it has failed. There is a relay that plugs into the compressor electrical connections and a start capacitor that is attached to that relay. Its a relatively low cost adventure to replace those 2 components maybe 30 bucks at the supply house. Otherwise if the condenser is clean and the condenser fan is running and the component replacement doesn't help you're going to need to buy a new compressor. Hope this helps and good luck.
    Apr 30, 2014 | True Refrigerators
    My refrigerator no make ice and the frezer no is cool
    Dear sir
    please make sure first your refrgetors compressor is working if its working and its not making the ice then it can be a low gas '{ free on } problem so pleae contact to your maintenance personnnel for further actuion .
    hope answer the question
    thank you
    plase vote !!!
    Jul 29, 2011 | Hotpoint Refrigerators
    GE side by side refrigerator 220 volts. Model #
    Hi again,
    Yes, 2HP compressor is what suitable for this model of refrigerator sir.
    Thank you for visiting FixYa!
    May 12, 2011 | GE Refrigerators
    Condensor fan runs. Compressor does not run and is warm to touch
    Your start relay may have failed. It is an inexpensive part to replace. Using an extension cord will cause voltage drop contribution to the problem, if you have an extension cord in the line, elliminate it and plug the box directly into an outlet. If none of these suggestions apply, then the compressor has failed. replacement of the compressor can rival the cost of a new refrigerator unless the one you have is still under a warranty. FYI, compressor warranties can vary but are typically for 5 years.
    Jul 11, 2009 | Amana Refrigerators
    My frezer is running warm and the My freezer is running warm and the ice maker is not working, I can’t get water to come out of the door. The refrigerator is running fine. MSD2657HEW
    I need you check a few things >>> is the freezer fan running is the back wall of the freezer have a heavy frost? are the condenser coils clean ..do you hear the compresser and fan motor running in the back of the unit
    May 10, 2008 | Refrigerators
    Refridgerator no longer colling but fans are working
    It impossible to tell via the internet without detailed descriptions of what you have tested, checked etc...However it sounds like maybe the compressor relay has failed if you are lucky, they are only around $50. If the compressor failed, then time for a new one probably if its more than 5 years old or if its a 2006 or newer.
    Jan 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
    Kenmore (253.51399104)side by side making buzzing/humming noise
    It will rattle slightly, this is normal. The ones that are burned out will sound like they have gravel in them, you can defininely tell something is wrong.
    The problem with diagnosing Kenmore fridges with this problem is that there are different manufacturers. Yours is built by Frigidaire and probably has a Tecumseh compressor. We find more failed compressors with the Tecumsehs than we do with the models that have Embraco compressors. The models with Embraco's generally have more relay failures.
    You should not hear the buzz/hum at startup. You will need to replace the compressor, which will be replaced at no charge to you if it is less than 5 yrs old.
    If it is older than 5 yrs, you can have it replaced, but it will be almost as expensive as a new fridge. You can buy an aftermarket start device called a 3-in-1. This has a start capacitor built in to give it a little more boost on start up. I don't recommend using them unless it is a short term fix until the compressor can be replaced or if it is out of warranty and there is nothing to lose anyway.
    Thanks/Mike
    Dec 06, 2007 | Maytag MFI2568AE Side by Side French Door...
    Refrigerators Logo
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
