Question about Time Computers & Internet
How to set time on model was-9075u-2s? - Time Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
Enter bios at startup.
Posted on Sep 11, 2017
Not working keeps beeping
<- With a full model number from the tag on or in the oven, I may have been able to give you specific help.
Without that essential information, I can only give more general advice.
I would ask for additional information, but FixYa no longer notifies us experts when such inquiries have been answered.
So you would need to post a new help request with the full model number from the tag, and symptom details - what it's doing or not doing, and when it happens.
Jan 20, 2014 | Microwave Ovens
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
Mar 18, 2013 | Hardware & Accessories
1996 toyota camry 2.2 5s- too manny timing marks crank shaft,cam shaft and cam shaft gears
Hi there:I dont have this diagram for 2S-ELC, 3S-FE and 5S-FE Engines, but pay attention at this...
To install:
  1. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  2. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  3. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly.
Remove any oil or water on the idler pulley and keep it clean.
  1. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  2. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  2. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  3. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  4. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  5. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt.
On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  1. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  2. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  3. Install the timing belt and check the valve timing as follows:
    1. Align the matchmarks that you made previously, and install the timing belt onto the camshaft pulley.
    2. Loosen the No. 1 idler pulley set bolt 1 / 2 turn.
    3. Turn the crankshaft pulley two complete revolutions TDC to TDC. ALWAYS turn the crankshaft CLOCKWISE. Check that the pulleys are still in alignment with the timing marks.
    4. Tighten the No. 1 idler pulley set bolt to 31 ft. lbs. (42 Nm).
    5. Make sure there is belt tension between the crankshaft and camshaft timing pulleys.
  4. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  5. Install the spark plugs.
  6. Install the right mounting insulator with bracket. Tighten the bracket bolts to 38 ft. lbs. (52 Nm), insulator nuts to 38 ft. lbs. (52 Nm) and thru-bolt to 52 ft. lbs. (71 Nm). On the 5S-FE, install the No. 2 engine mount bracket and tighten to 38 ft. lbs. (52 Nm); install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm).
  7. Lower the engine.
  8. On 3S-FE and 5S-FE engines, install the alternator and alternator bracket. On 2S-ELC engines, install the power steering reservoir tank.
  9. Install the drive belt and adjust the tension.
  10. Install the cruise control actuator with bracket.
  11. Install the fender apron seal and right engine under cover.
  12. Install the right front wheel.
Hope this helps.
Jun 12, 2012 | Toyota Cars & Trucks
What are the timing marks for a 1996 toyota camry, 2.2
When install,
align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
Apr 29, 2011 | 1996 Toyota Camry
Procedure in changing timing belt
Timing Belt and Sprockets REMOVAL & INSTALLATION 2S-ELC, 3S-FE and 5S-FE Engines
  1. Remove the timing belt covers as previously detailed.
  2. Raise the engine just enough to remove the weight from the engine mount on the right side.
  3. Remove the thru-bolt, two nuts, and right hand mounting insulator.
  4. Remove the retaining bolts and remove the right hand mounting bracket (from the side the alternator was removed from).
  5. Remove the timing belt and timing belt guide. If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear.
  6. Remove the bolt retaining the No. 1 idler pulley and tension spring.
  7. Remove the No. 2 idler pulley.
  8. Remove the crankshaft timing gear , if it can not be removed by hand, use two flat bladed tools to pry it off. Make sure to position shop rags to prevent damages to the components.
  9. Remove the nut retaining the oil pump pulley. To install:
  10. Align the cutouts of the oil pump pulley and shaft, and slide the pulley on. Retain the pulley while tightening the nut to 21 ft. lbs. (28 Nm).
  11. Align the crankshaft timing pulley set key with the key groove of the crankshaft pulley, then slide the pulley on.
  12. Install the No. 2 idler pulley with the bolt and tighten to 31 ft. lbs. (42 Nm). Be sure the pulley moves smoothly. NOTE: Remove any oil or water on the idler pulley and keep it clean.
  13. Temporarily install the No. 1 idler pulley with the retaining bolt. Hint: use a 1.65 inch (42mm) bolt in length. Do not tighten the bolt yet. Install the tension spring. Pry the pulley toward the left as far as it will go, then tighten the bolt.
  14. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Install the timing belt on the crankshaft timing, oil pump, No. 2 idler and water pump pulleys. NOTE: If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  15. Install the lower (No. 1) timing belt cover and new gasket with the four bolts.
  16. Align the crankshaft pulley set key with the pulley key groove. Install the pulley. Tighten the pulley bolt to 80 ft. lbs. (108 Nm).
  17. On 2S-ELC engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  18. Align the camshaft knock pin with the matchmarks on the oil seal retainer.
  19. On 2S-ELC/USA engines, align the knock pin with the pin hole on the timing pulley E mark side. On 2S-ELC/Canadian engines, align the knock pin with the pin hole on the timing pulley. On 3S-FE and 5S-FE engines, align the knock pin with the groove of the pulley, and slide the pulley onto the camshaft with the plate washer and set bolt. NOTE: On 2S-ELC engines, make sure that the Matchmark on the oil seal retainer and center hole of the small hole on the camshaft timing pulley are aligned.
  20. Using the removal tool to hold the pulley stationary, install and tighten the pulley set bolt to 40 ft. lbs. (54 Nm) on the 2S-ELC and the 3S-FE. On the 5S-FE, tighten the set bolt to 27 ft. lbs. (37 Nm).
  21. On 3S-FE and 5S-FE engines, turn the crankshaft pulley and align the 0 mark on the lower (No. 1) timing belt cover.
  22. Install the timing belt and check the valve timing as follows:
    2. Loosen the No. 1 idler pulley set bolt 1⁄2 turn.
  23. Install the upper (No. 2) timing cover with a new gasket(s). On the 5S-FE, align the two clamps for the engine wiring harness with the cover mounting bolts.
  24. Install the spark plugs.
  25. The remainder of installation is the reverse of removal. Tighten each component to specifications.
Aug 04, 2010 | 1996 Toyota Camry
Is the Advueu V800XPT-2s tablet pc obsolete? If
This is an obsolete tablet PC. It also goes under the model number EZ30 by Elitegroup. Two batteries were available, however neither is currently available. If you have the skills, you can rebuild your existing 3 cell pack with new LiIon cells. Use extreme care if you do, and make absolutely sure that you replace all the mechanical and electrical protection otherwise the pack may present a fire hazard. Also, there was an extended battery made for this model (11.1V 4400mAHr). The model number for the battery is 822V80010002. Good luck finding one though. I have seen a picture of only one, and the manufacturer of the battery is out of business. Also if you need support for this unit, it is still available from Elitegroup at http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=3&DetailID=386&DetailName=Feature&MenuID=93&LanID=0
Mar 11, 2010 | Advueu Technology V800XPT-2S Tablet PC
Which key to enter to bios to format pc IBM pentium III
del.. button on your keyboard old models may require F6
Nov 19, 2008 | IBM ThinkPad T23 Notebook
Blank sreen after bios update
Update BIOS with Boot Block Error Code/Beep:
Definitions Error Beeps Error Code (Port 80H)
BIOS updated successfully. 2L-1S-1L F1h
The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h
The BIOS file can't be read; it is defective. 1L-2S F2h
The model ID is mismatched; wrong BIOS file. 3S F3h
The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h
The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h
No diskette, or cannot locate the BIOS file.
Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
Mar 27, 2008 | Acer Aspire 1640Z Notebook
Computers & Internet Logo
56 people viewed this question
Top Time Computers & Internet Experts
Mike Tramer
Level 1 Expert
Taelisin
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
