Question about Russell Hobbs Irons
I have a Russell Hobbs steamglide iron model number 18721 that suddenley switched off and went cold during ironing why
I have changed the fuse but the red light will not come back on
    Top Expert:
  • Russell Hobbs Master
  • 36,477 Answers
The heating element may have failed abruptly.
Posted on May 01, 2017
Testimonial: "How can I check to see if that is the reason"
The red security light is on permanently
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If the light stays on then you have an issue with the unit and i would get a professional to help.
West Palm Beach Air Conditioning
Feb 15, 2015 | Tefal Irons
Russel hobbs 14546
if you want to open it up the screws are hidden, and you need to carefully prise off both the blue filling funnel at the rear, and the surround for the water spray nozzle at the front (knife or thin blade driver). Then you will meet a mix of pozi and anti-tamper screws needing a fork driver. The power supply for the blue LEDs is wrapped in a disconcerting gold coloured (mylar) pouch, and does not affect operation. The thermostat and the supply to the red neon light are all in the base plate with the element, the overheat fuse is in a "sausage" of sleeving P clipped to the baseplate. In our case this fuse had gone open circuit, and temporarily shorting this out restored normal operation until a spare could be located.
Apr 11, 2013 | Russell Hobbs Irons
DX8800 iron power light (red in handle ) comes on but, no heat to foot and water comes out the bottom hole on each side of foot when tipped one side or the other
Ur iron needs to check and adjust the THERMOSTAT SWiTCH for the heat! Check also the THERMAL FUSE that might been blown and replace it w/ similar part! U need to bring that iron to ur electronic technician if u can't dismantle it to adjust and replace the said parts! hope that may help u out!
Nov 13, 2010 | Rowenta DX-8800 Iron
Red light on
element is shot,take it back or send it back for repair
May 31, 2009 | Tefal UltraGlide Easycord FV4256 Iron
Iron shut off; will not go back on
There is a thermal fuse in the iron which blows when overheated. This fuse has to be replaced.
You can probably find one on-line at radioshack.com -- match the temperature rating of the old fuse. It'll have to be crimped in -- if you solder it, the heat will blow it.
Apr 29, 2009 | Black & Decker AS100 Iron
Not heating
The thermal cutoff device blew and must be replaced. It acts like a fuse when the iron gets too hot. Thay are very
cheap and it would be well worth replacing. Hope this was helpful.
George
Mar 24, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta autosteam iron dz 1700 r
The electronic device is faulty and need to change inorder for the iron to work properly.
Regards
alan
Feb 23, 2008 | Irons
Red light flashing
Blinking red light is a standby phase, its not going to get hot like this. Shake it or just start ironing, the red light will go solid and the plate will heat up. The red light will go off when the plate is hot enough. It will go on again (solid) after a few minutes to keep the plate at the right temperature. If you leave it standing around for a while it will begin blinking again (standby).
These irons are known for malfunctioning though, mine stays in standby and the plate never heats up! Hopefully yours is fine.
Feb 07, 2008 | Braun SI6225 Iron
Red indicator doesn't turned on
where is the thermal fuse for this iron? mine has the same problem, I don't know what to look for.
Jan 04, 2008 | Panasonic NI-H10NS Iron
Irons Logo
222 people viewed this question
Top Russell Hobbs Irons Experts
 Mikey
Mikey
ray gallant
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
