Question about PfaFF Sewing Machines
Pfaff 1467 needle jammed in fabric and hand wheel stuck
  • PfaFF Master
  • 11,462 Answers
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
Posted on May 01, 2017
Testimonial: "Very impressed with such a quick response to my machine problem. Unfortunately my Pfaff needs technician attention -but I couldn't give enough praise to the online engineer who tried to help me through this. Super service, thank you."
  • 5 more comments
  • Margaret Atkinson
    Margaret Atkinson May 01, 2017
    Thank you.
  • Margaret Atkinson
    Thanks for the quick post. Unfortunately this procedure hasn't solved the problem. There is no thread visibly stuck in the bobbin case which was easily removed from the machine and the needle has no thread in it either; the needle is halfway down (into the bobbin chamber) and halfway above into the fabric. Perhaps this requires the assistance of an engineer unfortunately ??
  • R.A. Ellis
    R.A. Ellis May 01, 2017
    Yes, it sounds like the needle is wedged into the machine, not trapped with thread as I originally thought. It would probably be best to take it to a technician as more than likely the machine has also been knocked out of time in this incident.
  • Margaret Atkinson
    Yes thought it was a bit tougher than I could solve. However I very much appreciate your assistance so thanks again for your efforts.
  • R.A. Ellis
    You are very welcome. Sorry I couldn't be of more help. BTW, I'm not an engineer... just a retired lady with a lot of home sewing experience.
  • Margaret Atkinson
    Margaret Atkinson May 02, 2017
    That hasn't half put a smile on my face ???? Well thank you ma'am. So glad I got to "speak" with you. Maybe some other time you'll be able to help me out ??
  • R.A. Ellis
    R.A. Ellis May 02, 2017
    Who knows??? Perhaps... A pleasure working with you.
I ran my Juki DDL 8700 without any fabric to test and the threads got sucked in and now the needle is jammed, when I turn the hand wheel it won't move the needle.
Loosen the needle. Once the needle is released, the threads holding it may loosen. Then gently try clipping jammed threads with tiny scissors and patiently try removing cut threads with tweezers..
Dec 21, 2017 | Juki Sewing Machines
I have a pfaff 261 when the knee pressor is engaged the motor runs but the needle doesn't engage. If i turn the wheel by hand the needle will engage.
First, stop running the motor if the machine is not operating. Most likely the old oil has stuck things together. Continued operation of the motor in such condition could burn up the motor or break a gear.
Pfaff 130 wheel sticks
Will not zigzag or decorative stitches New to these newer plastic style...
Nov 10, 2016 | PfaFF Sewing Machines
Pfaff 7570 - Had a problem with bunching threads, removed the knots and now the needle arm is jammed and won't go up and down. Any suggestions to remedy this problem?
It is quite possible that there are still some stray threads stuck or wrapped somewhere in the machine that are preventing the machine from operating properly. If unable to locate what is holding the machine, service may be required.
How to Troubleshoot Pfaff Sewing Machine eHow
Seams Like Paradise
Tension has thread caught in it
PFAFF Mail Repair Garry Machine
Jul 15, 2016 | PfaFF Creative 7570
Singer futura quartetis stuck in zig zag stitch. How do I get it out?
1.Switch off your machine and raise the presser feet up.
2.Raise the needle by turning the hand wheel towards you.
3.Carefully using your ripper or embroidery scissor to cut off the threads underneath the fabric(you may have to loose that part of your fabric if its too much entangled)
4.If the threads are still stuck in the bobbin case, use your GS screw driver to open the screws holding the throat/needle plate. Be very careful not to scratch the bobbin case when getting the threads out.
5.Once the entangled threads cleared, install back your bobbin case to be nicely seated on the grove of the rotary hook, then fix back the throat/needle plate. Before putting back the bobbin, turn hand wheel to bring needle up and down to ensure no jam. If OK you may proceed your sewing.
Nov 08, 2013 | Sewing Machines
Hand wheel stuck
Check to see if the needle is jammed into the fabric. Try pushing the REVERSE on the machine and give a little push to the hand wheel.
Jun 20, 2013 | Singer 3116 Simple
Loose tension
I would suggest taking the machine to a different repair technican
because the tension dial may need to be replaced.
the machine may also need some type of adjustment.
Apr 10, 2013 | Sewing Machines
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
May 10, 2011 | PfaFF Sewing Machines
Using a Pfaff Hobbymatic 935. Needle will not move, mechanism around bobbin will not move. Everything is locked in place. Tried cleaning everything, removed the needle (to get the fabric out of the way),...
It is likely the the bobbin holder is jammed up with cloth or thread. Take the bobbin holder out and turn the machine by hand, if it does not move it could have a broken timing belt or slipping coupling.
Apr 13, 2011 | PfaFF Sewing Machines
Sewing Machines Logo
94 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
