IRC4580i print double image after I refix the transfer belt
Image looks like a shadow and that double the image.
C-Dog
  • 84 Answers
SOURCE: Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Posted on Feb 18, 2008
SOURCE: double image
Jehill,
Would appeciate the procedure for ghosting on my Wega.
Thank you
Joe
Posted on Feb 29, 2008
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
jay-jay-g
  • 48 Answers
SOURCE: Brother DCP-110C multi-function, printed image has shadow/double image
Press Ink.
Press up or down arrow buttons to select Cleaning.
Press Set.
Press up or down arrow buttons to select Black, Color or All.
Press Set.
The DCP will clean the print head. When cleaning is finished,
the DCP will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Posted on Aug 21, 2008
pilot210
  • 39 Answers
SOURCE: multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Posted on May 18, 2009
How do I fix my Canon IR c5185 printing double image
Check the fusing unit if the heat roller engaged? The unfixed image at the roller causing Double image too in Canon IRc5185.
Nov 27, 2014 | Canon irc5185i
Samsung clp 315 printing shadow images
Ghosting appears often because of bad toner. If cartridges have been refilled, they have wrong toner in them. If drum has worn out it will usually tell you. All parts for this machine cost too much. If toner is not the problem, probably best to get a new machine rather than pay to get it fixed. Brothers are cheaper to run.
Sep 01, 2014 | Samsung CLP 315 Laser Printer
Image of last print shows up on presant print
This is usually caused by the left over toner not being properly cleaned from the transfer belt.
Open the printer front cover and close it. Wait for the printer to cycle. It usually make a little noise then stops. Then open the cover and close it again. Then print.
If the first page of the print out is clean. but the next page you print has a shadow of the first page, then you have a a problem with the cleaning mechanism.
Unfortunately the cleaner is part of the image transfer belt assembly which runs about $150 to $200. Unfortunately not terribly cost effective as compared to the original cost of many of these printers.
Good Luck.
Feb 11, 2014 | Samsung CLP-315W Laser Color Printer
Printing shadow
Hi Christian,
There some possibilities of this problem: drum cartridge / transfer belt / transfer is exhausted, laser scanner assy is faulty.
Jan 14, 2014 | Canon imageRUNNER iR C4080 Color Copier
Printing shadow from previous page
transfer belt damage please replace transfer belt or transfer belt wiper blade
Sep 28, 2011 | Samsung CLP-500, 550 Image Transfer Unit
Quilt y of print !, it gives double printing on page one is print of original doc.& second as its image what should i do to improve its print quilt y. i will be thank full to you
Dots, Lines, shadows and smudges on the printouts are due to dirty/ deteriorating cartridge and cleaning the green drum of the cartridge may help temporarily. Take out the cartridge and gently clean the roller/ green drum with a dry, soft, lint-free cloth wiping off the toner dots marks/ lines.
Also, make sure that the visible inside of the printer is clean and ther is no spilled toner inside, which sometimes results in dots. Double printing is also due to the deteriorating cartridge. The drum is not getting clean after its each rotation and hence the remaining toner/ image is transferred to the paper resulting in double printing. So, it is recommended that clean the drum etc (this would help temporarily). Also, make sure that the toner cartridge is in good working condition. If not you may replace the cartridge.
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Jan 14, 2011 | Canon Image Runner 1630 Copier Copier
I am experiencing some "shadowing" when I print a document
The problem most like resides in the ETB or electronic transfer belt....The image is not being removed from the belt to the paper causing shadowing effect...you need to replace the ETB. Try www.getthatpart.com they have great units at great prices and have someone on the phone you can talk to. If you feel its not the ETB and you don't see any toner left on the belt call these guys up and they can help you futher
Oct 25, 2010 | HP Color LaserJet 2600n Printer
Color printing problem printing in double image looks there is registration problem irc3200 canon
this is allmost allways the transfer belt assy if you have over 200k on the machine the belt is slipping ever so little. you can take out the unit and remove the belt and clean all the rolles esp the largerer drive one. seen this many times
Dec 23, 2008 | Canon imageRUNNER C3200 Copier
Hp color laserjet 1600 copies have a blurred image
This sounds like a registration problem.
Use the menu (on the printer) to print antest page AND a configuration/information page.
Look (critically) at the alignment of the seperate coloure Yellow Magenta Cyan. You will probably find that these are out of aligmnent across the page.
The cause of this, is that the printer can't perform a calibration properly (printer probably takes a long time when calibrating too) and is usually down to failure of one of the sensors on the transfer belt.
Sometimes you can clean these and solve the problem, but often is a failure of the component itself. Thes are NOT available as a spare part, and the repair to correct this would need a replacement transfer belt.
Transfer belt replacement in this printer is quite an involved task, though it is within the capabilities of someone with reasonable mechanical aptitude.
Nov 24, 2008 | HP LaserJet 1600 Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
51 people viewed this question
k24674
jasbo
jasbo
