Question about DeVilbiss Air Tools & Compressors
Hello where can you buy a botom repair kit for my devilbiss shbn4 nailer
4 Suggested Answers
  • 1388 Answers
SOURCE: repair kits
I have been repairing Makita handtools for many years and generally order parts from two sources.
If I have the breakdown and know the part/kit number I will call Makita at 1-800-462 5482. A live person will help you with your purchase. Other times I order from Tool parts direct has parts lists and prices for many brands and is easy and convenient if you pay with credit card. Nothing prevents you from looking up a part at toolparts and pricing that part thru Makita. If you are a business may I suggest opening a commercial account at toolpartsdirect to qualify for a generous discount. I rarely order a repair kit favoring replacing only the necessary part to save money. However, sometimes the custmer wants to completely rebuild the tool; since the customer rules, a kit is the best way to satisfy. Good luck.
Posted on Jan 22, 2009
  • 1388 Answers
SOURCE: i need a repair kit
Could not find parts listing for your nailer. It must be an old number from Harbor Freight. Thier nailers however are China copies or popular brands. Take the part that you need to a fastener company that deals in popular brands of nailers and with measureing tool in hand, ask them to try to match. I have had luck with some porter cable parts fitting central guns. Look here:
find a porter cable fr350 nailer parts list or bostitch n80. It they look similar then parts for porter cable are sold thru Dewalt service center (for actually looking and measuring the part) .
Posted on Nov 21, 2010
SOURCE: need repair kit for central pneumatic 8 to 10 GA
read all your answers and here is a solution
i needed a manual for a 39092 nailer, old harbor freighs had no comment, to old. so i found a new nailer, scrolled to the manual section and brought it up.
i then changed the link to reflect my series
mine was a 39series the new a 68. it appears they catalog by a 5 digit code. this got me a drawing and part list.
Posted on Oct 23, 2012
How do I find replacement bumpers for a devilbiss shbn4 trim nailer?
Morning gyascutis,
The bump is #18 of which: Key Numbers 16, 18, and 22 can only be purchased as part of NSK-007 Bottom Repair Kit. As we don't have this tool range in the UK, I'd suggest that you DeVilbiss
Call our Toll Free Number 1-800-888-2468, Ext 2, then 1, to obtain
the location of the nearest Authorized Service Center for ordering repair
parts and for warranty repairs.
Sep 25, 2014 | Air Tools & Compressors
Where can I buy a o-ring kit for a bostitch nailer #sb1850bn ?
Stanley Bostitch makes very few o-ring (rebuild) kits for thier nailers. Your brad nailer never had a kit available. You have to go to a service center or website like, find a breakdown of your model and order each o-ring seperately. Your nailer is an older tool that was sold as part of a combo kit and there are many parts that are no longer available or are shown on back order which usually means the same thing. If you have someone in your area that works on pneumatic nailers they may have o-rings from other manufacturers that will work.
Feb 22, 2013 | Stanley Bostitch SB1850BN 18Gauge Brad...
Model SHBN4. Piston does not withdraw after actuating to allow nail to come into position to be fired.
Piston does not return to top is caused by bent driver, worn lower bumper missing check valve or worn piston oring. Remove the head and pull out the cylinder and driver. Check the driver for bent shaft and that the piston/oring fits snugly into cylinder; make adjustment as needed. The lower bumper should not be cracked or missing pieces. Below the bumper is a seal that should fit snugly around the driver blade. Most all nailers have a check valve around the outer lower part of the cylinder. Could be oring or look like rubber band. This checkvalve will fit snugly over a series of holes cut into cylinder and causes the piston to return to top (not all nailers have this checkvalve). Lube all parts with silicone paste lube or nailer oil. Good luck
Aug 23, 2011 | Itw Devilbiss Tools & Hardware - Others
I can't find parts for devilbisss model QFH501, serial no. F-8-056
The Repair Kit has the number KK-4058-1. You can find more information here:
Jun 14, 2011 | DeVilbiss Paint Spray Gun Repair Kit For...
Air "runs "straight through without nailing.
The most troublesome part within the cnp65y is #knp-me-110-3p1, cylinder ring assembly. If this part is bad, air will leak out the nose. This white plastic ring seals the cylinder to body and is visible when head is removed. Pull cylinder and remove the ring. Examine for cracks or anything unusual and replace as needed. Available at Good luck with your repair.
Aug 19, 2010 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
I need part for a SFN6 DEVILBISS NAIL GUN
I found a solution to the discontinued check seal part #nsp-199.I can get one that is a perfect fit.
Jun 22, 2010 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Need a kit for a devilbiss nail gun N6 the big seal in the top of the head is blowen
go to the site of tool parts direct. they can get you an o ring kit for your gun
Oct 20, 2009 | Itw Devilbiss Tools & Hardware - Others
Weres the modle number
Your tool in the photo is Duo Fast CNP50 coil nailer.
to double check your self go to the paslode web site and go through the model listings. Good luck.!
May 11, 2009 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Air Tools & Compressors Logo
126 people viewed this question
Top DeVilbiss Air Tools & Compressors Experts
ray gallant
Lawrence Oravetz
Are you a DeVilbiss Air Tool and Compressor Expert? Answer questions, earn points and help others
