Question about Garden
Shrieking Lawnmower!! I hit small tree branch w/ walking non-drive 3.75 hp Briggs and Scrap-Iron "Sprint" off-brand gas mower. Started shrieking like banshee. Resulted in tangled pull-cord. So I removed pullcord housing and re-wound pull cord. Now, upon re-start, ran ok initially, until I encountered first bit of grass---now shrieking continually before encountering resistance, runs out of balance a bit, and upon engine kill I observe slight loss of tension on pullcord. So it must be, what, a belt? and/or the upper pullcord rewind assembly is involved somehow? Central shaft involved I suppose--it'd be nice if someone tells me what I should look for and/or best steps for teardown. thanks a million!!!!
  • 112 Answers
Sounds like you have dirt in the recoil clutch, (under the screen) or you bent something there. try removing the clutch and make sure shaft is very clean and lightly coated with oil. This would be for a briggs and stratton engine.
Posted on Jul 25, 2009
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Craftsman gold 6.0 hp. walk behind lawnmower wont start
Back to basics, is the fuel in the tank good?( fill with fresh fuel ) does it have a spark at the plug?(remove the plug, earth against the cylinder, is there a spark,if not, replace the spark plug and try again ) does the plug wet with fue lafter pulling?( clean/service carb ) is the spark occuring in the correct place ( flywheel key sheard ) has the engine got good compression?
Aug 19, 2013 | Briggs & Stratton Briggs Stratton...
8 hp B&S amf dynamark rider ran it out of gas, since filled w/new gas starts but quits running after 3-5 mins
try and run it with the gas cap loose when you refueled it dirt might have blocked the vent on the cap
Jul 10, 2012 | Briggs & Stratton Briggs Stratton...
Will putting oil in the gas tank of a 2 cycle lawnmower riun the engine?
It is not good for that motor--drain and clean and expect plug may get fouled---do it the sooner the better.
Jun 15, 2012 | Briggs & Stratton Briggs Stratton...
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
How do i replace a pull cord on a b&s 3.75 sprint lawnmower?
it is a small engine just buy a new one it will be cheaper in the long run and save yourself some trouble
Jun 12, 2011 | Briggs & Stratton Briggs Stratton...
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
Shrieking noise when driving.
you have a belt thats either too loose or too tight..you need to have them checked and have them adjusted
Jan 13, 2009 | 1999 Dodge Intrepid
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
