Question about Beko Washing Machines
My Beko wmb81241lw won't do self clean finishing cycle after about 10minutes instead of 2hrs 26 min , think other cycles are ok
  • 26 Answers
SOURCE: kenmore model # 20722990
It sounds more like the timer motor is stopping. There mght be something binding or a dead spot on the motor.The next time it does that, advance the timer slightly a few times and see if it then advances on it's own Check all the wires, too. Take the timer assembly out and flush it several times with alcohol or plastic safe electronics cleaner while operating the timer (engaged) several times.
Posted on Mar 30, 2008
  • 4070 Answers
SOURCE: door wil not open after self-cleaning cycle.Code
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Posted on Sep 18, 2009
  • 330 Answers
SOURCE: Keeps pausing in the middle of wash cycle. Sits
the timer is busted getting stuck at same point their expensive as well
Posted on Jan 05, 2011
  • 489 Answers
SOURCE: my new lg condenser dryer counts down on cycle to
This is normal. The computer is trying to determine if the clothes are dry enough. If not, it will stay at the 11 min mark and wait till the clothes dry a little bit more.
Posted on Jun 26, 2011
  • 3051 Answers
SOURCE: oven door won t open after self clean cycle
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Now if this has not worked then you will have to remove the top part of the oven to get to the latch asy which means you may have to remove part of the back of the oven or the entire back piece depending on your model to be able to remove the screws that hold in the top of the oven on the back then you should be able to see the latch mechanism
Now remove it and have it tested or simply replace it ok
Hope this helps please keep me informed on how this is going i can send you a link to a site that has a video on how this is done if needed ok to help you repair this
Best regards Mike
Posted on Nov 19, 2011
Beko WMB714422 .... washing cycle stops after 5 mins of the cycle and shows 'end'. Cant get it to do a full cycle. Any ideas ?
This is most likely an issue with the motor, causing confusion to the electronics, sometimes you can replace the motor and remedy the issue but I have had a couple of occasions with Beko machines where the motor fault caused damage to the control board
Jun 12, 2016 | Beko Washing Machines
How do you unlock the control locked function on a Maytag Gemini elec. range?
If its a self cleaning unit, try start the self cleaning cycle, then cancel it. If that doesn't work let the self clean cycle finish completely and it should go back to normal.
Mar 15, 2015 | Maytag Kitchen Ranges
I accidentally set cycle to Self Clean instead of Spin & Drain and pushed Start button. Trying to reset to correct cycle. Have just moved and don't have manual on hand.
Most machines will reset if you press the stop button or otherwise end the cycle. If all else fails, un-plug the machine, wait a few minutes and plug it in. Otherwise, just let the Self Clean cycle finish.
Nov 14, 2014 | Washing Machines
My beko washing wont do a cycle instead jumps to spin then whilst trying to do a spin it jumps all over the kitchen
Hi if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first. there are a few possibilities here see below
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Aug 21, 2014 | Washing Machines
**** beko dryer drvs62w
hiya my beko dsc85 8kg has stopped after finishing a cycle of clothes but wont restart just says drying but nothings happening and i have cleaned everything twice any advice on the problem would me much appreciated. thanks glenn
Nov 15, 2012 | Dryers
Beko washing machine WME 7267 fills with water but will not continue through the cycle
See if the filter is clean or if the exhaust hose isn't blocked.
Feb 23, 2012 | Beko Washing Machines
Can anyone help me with my washing machine (aeg lavamat 66840 l).After choose a washing cycle and the timer displays 2.20 h , the washing cycle finishes in 1.45 h !?Any ideas?
MARK 07779933829
Nov 22, 2011 | Washing Machines
Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Sep 09, 2009 | Washing Machines
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Washing Machines Logo
Top Beko Washing Machines Experts
micky dee
Domenico Grillo
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
