Question about Refrigerators
I have a pigeon pair fridge and freezer forgot how to connect them together with a joiner between them
2 Suggested Answers
Maytag317
  • 1136 Answers
SOURCE: glass shelf broken
Hi, there are replacements available. If you get me model#, I can get you part # and I can even order it and ship it to you.
Please let me know if you need more help.
Thaks
Vic
Posted on May 11, 2009
How do I bypass the heater core on my 1996 Mercedes c230
Randy, Locate the 2 heater hoses running into heater core,(they will be sticking out of firewall), Cut these heater hoses off by the firewall and use a ribbed brass joiner (hose joiner) of correct size for heater hose and gear clamp both ends. Its as simple as that to bypass heater core.
Show your gratitude and press the helpful button and follow me on fixya for more tips and info.
Feb 18, 2016 | Cars & Trucks
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Freezer drips water into fridge
There is drain tube that empies into a small pan at the bottom of the fridge. Follow it up to see where it connect and make sure its in place. If your freezer is constantly defrosting itself and wont keep your food frozen you might want to replace the bi-metal. The "bi-metal" is a small coin sized thermostat of sorts. Its easy to replace if you can splice wires together and wrap in black tape.
Remove the back panel inside the freezer and look for a quarter sizes disc with two wires coming from it. Cut the wires leaving enough to splice the new bi-metal into place and wrap each wire with black tape. This will fix 99% of the problems with freezers always in defrost mode and leaking water into a fridge.
Jul 18, 2011 | Whirlpool Refrigerators
Wse6070sb fridge. Leaks water down by the door hinge. How does the internal door lining come off so I can see where it is leaking from?
The problem is that the pipe that feeds the filtered water is broken. It is a common problem. If you are handy you can fix it. You buy an 8mm press fit elbow. Google it. If you want to see what these are you need to look under the fridge. The best way to do this is tilt the fridge to one side and then put a piece of wood under the gap. Tilt the other way and put wood under the other side. Keep doing this until you can see the white pipe under the corner of the door. Your will see a that the pipe is cracked at the bend. You need to fit the 8mm elbow onto the cracked pipe. This is not easy. Make sure that you wind the adjustable feet down so that the fridge does not crush the elbow. On my fridge the pipe was brittle and weak. I took a piece from the filler end.
If you look under you will see a clear pipe that is joined to the white pipe. That joiner is an 8mm push fit joiner. You need a 90degree version to join at the cracked bit. Once you have the joiner, carefully cut the crack through and push the joiner UP first, then fit the other piece in. Be careful to tuck the finished pipe away. When I did it the fridge crushed the joiner when I took away the timber.
Jul 14, 2011 | Westinghouse Refrigerators
We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
Apr 24, 2010 | Woods Upright Freezer MU07W
The fridge compartment of fridge freezer has stopped working.the freezer doesn't seem to be freezing correctly and frost/ice is building up around the insulated pipe where it enters the freezer at the...
I removed the freezer drawers removed back panel inside the freezer,and discovered that ice had built up around the vent which cools the fridge compartment once I melted this using a hair dryer put it back together and the fridge compartment works fine.
Dec 29, 2009 | Refrigerators
Glass shelf broken
Thaks
Vic
May 11, 2009 | Refrigerators
Area between the doors on the side by side are really hot.
Hi!!! the door was left open some forgot to close the door..if you have more problems let us know..Good luck..
Jan 04, 2009 | Jenn-Air JCD2389G Side by Side...
Fridge Feezes
My Candy fridge freezer done the same. After a bit of investigation, I found that the little plastic shaft from the front temperature dial that connects to the thermostat has snapped. I merely glued it back together and it worked fine.
In essence, the thermostat was turned on to super all the time, and turning the dial anti-clockwise did nothing as it wasn't connected to the thermostat.
Very flimsy I say.
Apr 08, 2008 | Candy CPCA240FFK Bottom Freezer...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
