Is there a switch for back. Up battery first time using it doesn't Light up. Clock?
    Top Expert:
  • Audio Player... Master
  • 49,215 Answers
No there is no switch
Posted on May 01, 2017
Honda CBF 1000, '07. The time on the clock can't be kept on the memory.
That will happen if there is no power to the clock. I assume the battery is not flat as you can start it. My clock is always on, even without the ignition on and if I disconnect the battery it restarts at 1:00 am. I would check to see if there is power to the clock with no ignition and the wire is not broken in the loom somewhere. I say this because power is obviously getting through when switched on. You will need a wiring diagram for your bike. It is possible it may be connected via an "auxilliary circuit".
Jul 20, 2015 | Motorcycles
How do I change from military to 12 hour format on the time display of the Sharp Atomic Weather Station SPC1003
Resetting: 1. Remove batteries from both the outdoor transmitter and the Temperature station. 2. Wait at least 30 seconds and then repeat the procedures specified in Setting up (above). Note: Always wait at least 30 seconds after removing the batteries before reinserting, otherwise start up and transmission problems may occur. Also, remember when insertting, that both units have to reset and to always reinsert the batteries to the transmitter first
    • 1 Insert the batteries into the clock and verify that the clock's display is functioning.
    • 2 Set the correct time-zone and Daylight Saving Time (DST) switches. The switches are on the back of the clock. Select EST if you are in Eastern Standard Time, CST if you are in Central Standard Time, MST if you are in Mountain Standard Time, or PST if you are in Pacific Standard Time. The DST selector should be set to "off" or "on" depending on the laws of your state.
    • 3 Wait 15 minutes. The clock should synchronize automatically.
    • 4 Set the clock manually using the buttons on the back panel if the clock does not catch the radio signal within the first 15 minutes. Push the correct button to advance the month/day/year on the calendar; use the MODE button to set the hour and minute.
    • 5 The clock should adjust itself within 48 hours to match the atomic signal. Verify that the clock is receiving the signal by checking the front display. You should see the image of a tower with circular lines at its top.
Read more :
May 08, 2015 | Audio Players & Recorders
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more :
    Jan 29, 2015 | Audio Players & Recorders
    Ti04 clock rotates and new trippers but doesn't turn on
    You probably have T104 timer.
    Clock rotates so power to timer motor is good. This means 240Volt breaker is good.
    Use override lever and see if Load (light, fan, motor) turns on and off. If override does not turn Load on-off, then bypass timer and see if load works. Move wires from terminal 2 to terminal 1, and terminals 4 to terminal 3.
    Did you order correct trippers?
    Copy following links for Intermatic troubleshooting and Intermatic parts list.
    Jun 28, 2012 | Intermatic T104 24h 208-277v Mechanical...
    Need manual for Travel Companion Model S1500 Alarm Clock
    Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
    1. Power source
      • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
      Changing the time
      • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
      Setting AM/PM
      • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
      Setting alarm time
      • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
      Turn alarm on
      • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
      Music options
      • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
    Read more: Travel Alarm Clock Instructions '
    Sep 22, 2011 | Vacuums
    Clock does not rotate
    If clock does not rotate, then check if outlet has power. Check for loose wires.
    If clock rotated before and stopped working, then clock motor might have gone bad.
    Replacement clock: Taco timer uses the FM1 timer module.
    Voltage and timer information appear on back of timer.
    Open following links to identify timer and model number:
    For example Taco timer module is 24 hour, and 120Volts, and doesn't have battery back-up.
    -If timer has on-off-timer switch, then model number is FM1STUZH-120U
    -If timer does not have on-off-timer switch, then model number is FM1STUZ-120U
    More resources:
    Sep 17, 2011 | Taco 265-1 / 563-2 Combination Analog 24...
    I need help setting the alarm on my radio controlled digital clock.
    1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    27 people viewed this question
