Question about Stainless Refrigerators
Stainless steel cleaning - Stainless Refrigerators
SOURCE: scratched stainless steel
First, I would not use ordinary steel wool. Small microscopic iron particles get embedded in the stainless steel surface and could lead to rust. There is stainless steel wool, but I have experience using sand paper, so I'll tell you about that.
When changing a faucet, thinking it wouldn't harm a stainless steel sink, I used a kitchen knife to scrape that crusty residue left from hard water. I had put in several noticeable shallow scrapes on the top part of my sink where everyone could see it.
I used a series of silicon carbide, wet/dry automotive sanding paper to hide my blunder. First 400 grit, then 600 grit, then 800, then 1000. The 1000 grit was actually to "polished" looking so I went back and finished with 800 grit, blending the refinished area out to the rest of the sink top surface. I sanded in the direction of the surface graining.
For your backsplash, the type of finish will determine what grit you'll finish with. If is it polished to a high lustre, then you'll have to go to finer grits. If it is polished to a mirror finish, then you'll have to eventually finish with a polishing compound.
While working on my sink, I had gravity to help me put weight behind my work (so to speak), but on your backsplash you'll have to awkwardly push sideways to work the sand paper, plus you may have cabinets in the way and a hood to clunk your head into. Depending on how much trouble it would be, you may find it easier to remove the backsplash.
I you are not familiar with finishing metal, you could practice on a piece of sheet metal first, getting used to how much pressure to apply, and sanding in straight strokes so you can match the backsplash's surface graining. If your backsplash has a mirror finish, you could try a polishing disk on a drill or a dremel tool first.
Posted on Oct 02, 2008
SOURCE: How to clean the stainless steel stove top
Someone else suggested Easy Off Oven Cleaner (I used fume free). I just finished using the Easy Off (make sure you cover the electronic ignition) with Q-Tips and my top looks almost as clean as when I first got it.
Posted on Sep 07, 2009
milten1
  • 1304 Answers
SOURCE: What is preferable - a stainless steel gas stove top, or a black?
black enamel
heres why
salt and grease get baked to the stainles steel
most scrub to get clean
very quickly this dulls and eventuly wears the steel and it looks drab
the enamel will alwsys look good
Posted on Oct 05, 2009
SOURCE: Stainless Steel Range Tops.
The only way to clean it is with steel wool. I use 2 different grades, but finish with a fine grit-0000. You still can't get it completely clean, no matter what you do. Forget it looking new. It's not real stainless steel if it's model FEF455BBA. I won't EVER buy this sort of top again either. I have had numerous problems with it, including since it conducts heat and doesn't shield wiring from the heat generated by the eyes, it is constantly melting out the plug-in elements for the eyes. I am surprised it hasn't been recalled. I am surprised more people haven't had fires!
Posted on Jul 20, 2010
walterkunesk
  • 683 Answers
SOURCE: I cannot clean my Samsung
when you clean the stainless make sure you wipe with the grain and not across it.
Posted on Apr 23, 2011
Tip
How to clean stainless steel appliances
Use extra virgin olive oil to clean and shine stainless steel. Apply with lint free cloth and rub into stainless steel following the grain of the steel. Then with dry portion of cloth buff like you would car polish and you will be amazed at the shine. It also provides some protection due to the fact it is a oil.
on Feb 02, 2015 | Kitchen Appliances - Others
How do I clean, what appears to be, rust marks on my stainless steel refrigerator
DO NOT use anything but a dedicated stainless steel cleaner. Some types of Windex have ammonia as one of the ingredients and you can imagine what that will do to your stainless steel finish.
Mar 23, 2014 | Samsung RFG297HDRS Stainless Steel
How do I clean my stainless steel surface on my Samsung Refrigerator. I have use several stainless steel cleaners and they all leave a film. I am unable to get out drip stains from water.
Start with soap and water to remove old polish, then use CLR to remove build up, then use a product called Stainless steel Magic to clean. Make sure when your done to buff off all remaining cleaner
Jun 14, 2012 | Samsung RF265AA Bottom Freezer French Door...
How can we clean the baked on food from the oven racks and rack holders? Stainless steel cleaner does not touch it.
To clean the stainless steel without marking it you can first try non-caustic oven cleaner, if you use normal oven cleaner the acid in the cleaner will etch "eat" the surface of the stainless steel
May 05, 2011 | Electrolux 30" Built-In Single Electric...
How to clean maytag stainless steel finish on appliances
HOW TO CLEAN MAYTAG STAINLESS STEEL REFRIGERATOR:
Do not use abrasive or harsh cleaners such as window sprays, scouring cleansers, flammable fluids, cleaning waxes, concentrated detergents, bleaches or cleansers containing petroleum products on plastic parts, interior and door liners, or gaskets. Do not use paper towels, scouring pads, or other harsh cleaning tools.
How do I clean and care my stainless steel surfaces such as refrigerator or any other stainless steel made appliance?
NOTE: Just because a cleaner is a liquid does not mean that it is nonabrasive. Many liquid cleaners designed to be gentle on tile and smooth surfaces still damage stainless steel.
> Avoid Citric acid
-it can discolors stainless steel. To avoid damage to the finish of your stainless steel appliance, do not allow these substances to remain on the steel finish:MUSTARD,TOMATO JUICE,MARINARA SAUCE,CITRUS-BASED SAUCES,CITRUS-BASED PRODUCTS.
If you want to clean safe and keep the sparkling steel you can purchase STAINLESS STEEL WIPES this wipes is ideal for cleaning food spills,grime and stains leaving surfaces shining like new. This wipes is for stainless parts only make it sure this stainless steel wipes to come into contact with any plastic parts.BUT THE SAFEST WAY TO CLEAN STAINLESS STEEL SURFACES IS TAP WATER WITH CLEAN WHITE CLOTH.
Jan 26, 2011 | Maytag Refrigerators
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Streaky stainless appliances.
Hellocmmirabile,
Welcome to Fixya,
You asked, What do you use to clean stainless appliances so they won't streak?
At this site of our sponsor, they have a good stainless steel cleaner.
http://www.pcappliancerepair.com/cleaners.shtml#cleaners
Stainless Steel Cleaner - 10 oz
P/N: 31462 Stainless Steel cleaner made by Whirlpool. Cleans and polishes stainless steel. Non abrasive and residue free. 10 oz bottle
Availability:
In-Stock $ 6.99
I use a $1.00 bottle of alcohol from the dollar store,
which is already mixed with water 80-20% OR or 50-50 %.
What ever they have available and I do it twice.
Let me know how you do.
Thank You for using our site.
Huuum,
Please remember to leave a solved rating at fixya
Oct 21, 2008 | Stainless Refrigerators
Refrigerators Logo
Top Stainless Refrigerators Experts
Dan Webster
Dan Webster
billconfused
Are you a Stainless Refrigerator Expert? Answer questions, earn points and help others
