Question about Acer Computers & Internet
Is my new HT231HPD Touch screen monitor compatible with Acer laptop running Windows 7.
  • 57 Answers
SOURCE: No sound from my laptop, acer 5520G running Windows 7
try these, they are for windows xp, they have worked for many people ...
http://www.bioticaindia.com/download.php?file=5520g
otherwise go to device manager, and check it's properties, then click on the details tab, click on the drop down menu below Property, select hardware IDs and post whatever is written in the value box...
Posted on Nov 27, 2009
donfwhite
  • 122 Answers
SOURCE: How can I make Windows 7 compatible with Dazzle DVD Recorder?
No... the only way is if Dazzle makes an upgrade or patch. Win7 is closing the door on Software that is not Certified for this specific OS. Good and Bad... mostly Good... for the long run...
You can contact Dazzle... they may discount or help if you are a loyal client :)
Posted on Jan 01, 2010
anandg27
  • 1272 Answers
SOURCE: Is Netgear Route WGR614V5 compatible with Windows 7?
Please note that this router is compatible with Windows 7. Please perform the below steps on your Windows 7 computer to connect to the wireless network:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 06, 2010
SOURCE: blue screen, launch manager, and empowering acer with windows 7 os
how can i setup the lunch manager in windows 7
Posted on Mar 10, 2010
freetek
  • 5568 Answers
SOURCE: Olivetti ANY WAY printer to windows 7 laptop
The best place to check for a new driver is on Olivetti's website since they are responsible for supporting their products. Unless the unit is very old, they will probably have a driver for it in their support section.
Posted on Apr 21, 2010
Testimonial: "THANKS VERY HELPFUL"
Acer screen jumping
Check to see if the button is stuck on your monitor and remember the last thing you did before it started doing this problem.
Jan 15, 2013 | Acer Aspire Z5801 All-In-One Desktop PC...
Can I install Windows 7 on an Acer Aspire 9410-4933 which is running Vista?
Most likely you should be able to install windows 7. I checked with Microsoft's minimum requirements, and your computer seems to fit the criteria
May 26, 2011 | Acer ASPIRE 9410-4933 COMPATIBLE LAPTOP...
My Acer Aspire crashed. A friend of mine resuscitated it using Windows 7. Unfortunately I cant turn off or control the touch pad click feature, and the pad scroll toggle button and DVD pad controls dont...
Installing a newer operating system on older computers, especially laptops, tends to cause compatibility issues like this. These problems are happening either because you don't have the necessary drivers to run the laptops hardware, or drivers for that hardware and the Windows 7 OS are nonexistent. You may be able to solve the problem by "rolling back" to whatever operating system the laptop was purchased with. But sometimes when these drivers are removed, by installing a newer version of windows the only way to get them will be contacting the manufacturer.
Apr 04, 2011 | Computers & Internet
Have LG W2343 monitor. Just purchased a new HP computer which has Windows 7, but having trouble with the size resolution on my screen. Monitor worked fine on my old HP computer which had Windows XP
You have to look hereto see if it is compatible with Windows 7,
http://www.microsoft.com/windows/compatibility/windows-7/en-us/Browse.aspx?type=Hardware&category=Displays&subcategory=LCD&showallcats=true&v=LG%20ELECTRONICS
Otherwise you will need Windows 7 driver from LG if they have one.
Most monitors works fine without the need of the drivers when running XP, but Windows 7 you need the correct drivers to get the correct resolution setting, that is one of the reason I do not care much for Windows 7 until they fix this problem, since a lot of people out there that still have great working monitors that work just fine with XP, most manufacturers do not provide drivers for Windows 7 for old monitors because they want you to buy new monitors.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Jan 04, 2011 | LG Computers & Internet
Acer Aspire 5610Z. Upgraded to Win 7. Screen resolution changes
Your laptop was not designed to run windows 7 or be compatible with it. It may run fine with windows 7 but issues might come up sooner or later like the one you're experiencing.
[EXPERIMENTAL]
Download both of these (as I don't know which one of thsese two your laptop needs). Keep mind that doing the following could render your system inoperable and use at own risk. When downloaded, extract ZIP , open desired folder and find SETUP or INSTALL program. Right click and choose properties, then navigate to compatibility mode, then select windows Vista from the menu. Then apply changes, ok and close window and attempt to start.
Acer Aspire 5610Z VGA Intel Driver Vista
Acer Aspire 5610Z VGA NVIDIA Driver Vista
May 27, 2010 | Acer Computers & Internet
Is this monitor compatible with a new desktop running windows 7?
At the Microsoft Windows 7 Hardware Compatibility Center, there are no Xerox monitors that have been determined to be compatible with Windows 7.
May 07, 2010 | Xerox XL350 (Silver) 15 in. Flat Panel LCD...
My PC's startup and game screens too far left
There may have been a software driver for your monitor for windows Vista to set the correct parameters
- here’s what I found on Microsoft’s site but only for Windows 7
https://support.microsoft.com/en-us/help/14108/windows-7-change-screen-resolution
Here’s some info about drivers for monitors on windows vista and 7 :
https://uk.answers.acer.com/app/answers/detail/a_id/4085/~/monitor-driver-installation-in-windows-vista-and-windows-7
Feb 06, 2018 | Hanns.G Corporation HW173D Monitor
Hello, Is the Windows 7 is compatible to my Acer Laptap
I would recommend sticking with windows xp on this model. New laptops are getting very inexpensive for the cost of windows 7 your better off buying a new laptop for 300$. If you operating system is performing up to what you think it should. I would consider backing up important data and formating and reinstalling windows.
Thank you,
Lee
Dec 05, 2009 | Acer Aspire 3000 3005WLMI Notebook
I just upgrade to Window 7, to my ACER AspireOne Netbook. Successful install with no problems. I have Acer X163W Monitor to use with my Acer Netbook, before install Win 7, I was able to setup the monitor...
As of now, there are no Windows 7 drivers for that monitor.
Here is the Vista driver:
Acer X163W Vista 32-bit Driver
You can try installing this in Windows 7 using compatibility mode and see if it works. Otherwise, just try to contact them directly or try and submit a query about it.
Oct 31, 2009 | Samsung 941BW LCD Monitor
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
