Weld not detect see manual user error - Washing Machines
Tip
Whirlpool duet F70 and F71 error codes.
F70 and F71 are two logic board error codes that point at a communication error between the main logic module and the control pad (user interface and CCU), and between the motor control unit and central control (MCU, andd CCU that is main control module).
Repair is difficult, as motor, wiring and voltages from control modules must be tested.
Try first doing a reset, by disconnecting power cord or tripping circuit breaker and leaving power off for five minutes.
If that does not help and errors come back, then the best thing to do is calling the service number listed on the user manual.
Here extensive explanation of error codes and relative troubleshooting:
F70: CENTRAL CONTROL UNIT HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the Central Control Unit to the User Interface.
1. Check for continuity of the User Interface harness.
2. Check wire harness connections to the User Interface and the Central Control Unit.
3. Replace User Interface if drum is rotating.
4. Replace Central Control Unit if drum is not moving
F71: USER INTERFACE HEARTBEAT FAILURE
If a Central Control Unit Heartbeat Failure is displayed, no communication is detected from the User Interface to the Central Control Unit.
4. Replace Central Control Unit if drum is not moving.
To get parts and diagrams try entering the full model number in one of the websites below:
Enter the model number ..
To contact a repairer, call the number listed on the owners manual or use the Fixya directory (US only)
on Nov 05, 2010 | Whirlpool WFW8300SW
Weld detect error
Ribbon weld needs to be replaced.
Jul 01, 2014 | Printronix P7010 Printer
Weld not detect
ykoymgiccohoideraqepirij0rebaq8hginreqebdyeyideraqepiru8docagicai54jwymwicaglcqwrizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8bgjnbaqehhweymcebasefarizwqebir8xp8pkfngr0qq4oeaaaaasuvork5cyii=
Like the problem is not by the user fix it. Check the ribbon, check visually all about it is good.
Jun 25, 2014 | Printronix P7220 Matrix Printer
Weld not detect
Hi
The cartridge weld was not detected.
1.Clear the fault message.
2.If message persists, replace the cartridge.
3.If necessary, replace the weld sensor.
Feb 15, 2014 | Printronix P7220 Matrix Printer
I have a front loader MHWE3000VW12 it's giving me a code F70 Ineed to know what it means
Thanks
Jul 26, 2012 | Maytag Washing Machines
Instruction manual for use
If you have the user's manual there is some rudimentary information there. If you have a local welding supply company, their catalog may contain general information.
The short of it is you will need to develop a feel for your machine. When you start with scrap of the same size as what you will be welding on, select your heat setting for the matel thickness, and strike an arc- nothing fancy all you are going to do is adjust your wire feed rate until the weld sounds like fring bacon only as quiet as you can make it.
once you have that setting run a bead on a corner weld or a **** weld and look at the back side- if it the weld achieved full ***********, and looks like the top side- you have it set right. Ideally the weld pool will only be twice in width as the thickness of the metal to be welded in most situations. Neithert undercut nor excessively proud of the surface.
if you have the model number and make, find the homepage of the manufacturer (except Century) and download their user manual for that make and model of yours.
Jan 10, 2012 | Welding Tools
Whirlpool duet getting error code F70 and F71. When hitting start button, getting a clicking sound and nothing is happening. Cannot open the washer door as it is locked with clothing inside it.
Hi jreib29,
Hope this helps.
Thank you for using FixYa.
Sep 17, 2011 | Whirlpool Kitchen Ranges
GW450001AC Where can I find a manual? Where can I find the locking connectors on the welding machinge for the welding cables? Are they called small Dintz? Will this machine run 1/8 welding rod?
Try to find the manual from your local tool trader, or go to the manufactures website and give them the serial # and and you can print a manual. I've done it with heavy equipment. To buy the quick connects, just look up welding supply in the yellow pages. Always buy your welding tools and supplies from a lisceansed welding supply. And yes you can weld with 1/8th rod, but you have to turn it up to 140 to do so, and use a 7018 rod
Jun 25, 2011 | Campbell Hausfeld GW450001AC 140 Amp Stick...
Washing Machines Logo
61 people viewed this question
Top Washing Machines Experts
