Question about Bosch Kitchen Ranges
Bosch range hood is making noise but not sucking air. DKE 645 / DKE 945. Any advice welcomed.
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 75 Answers
There's a backdraft damper located in the ductwork either right at the fan, or where it exits the building. The grease filters could be plugged, or the fan itself could be plugged with grease also. If vented to the outdoors, the vent could be blocked by birds or other critters. Does the fan sound 'normal'?
Posted on May 02, 2017
Please can someone advise how to get at the switch board for a Bosch cooker hood E-Nr DKE 995 A GB and FD 8009.
many of the switches used are of the push in type and have little clips on the sides that need depressed to extract the switch . without the ability to see exactly what you have make it impossible for us to assist . contact an electrician locally .
Sep 21, 2016 | Bosch Kitchen Ranges
My bosch extractor fan makes such a noise when the light is on. I sometimes just use the light function of my fan when I'm cooking but it makes such a noise I can bear to keep it on for long. Is there...
check the vent is not restricted. I had had one where the installer accidentally stopped the butterfly flap from opening with a fixing for the flue. Also one where builder squashed the pipe in the roof. Another where there was no pipe from hood, not moving air at all,just a noise maker!
Oct 16, 2013 | Kitchen Ranges
Bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Dec 09, 2009 | Bosch DKE93xxUC Stainless Steel Kitchen...
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
My new magic chef oven makes a slightly sputtering noise all the time. It is not turned on, and I hear this noise. I am concerned it might not be hooked up correctly. please help! Debra p.s. it has a...
Hi Debra,
It sounds as if you may have air or water vapour in your gas line or burner. I suggest you contact your gas supplier or the manufacturer of the oven to get professional advice.
Regards
Alan Hood
ami-man
UK
Nov 25, 2009 | Magic Chef 31000 Gas Kitchen Range
Install the chimney cover
there should be 2 or 3 peices of alum off the hood predrill hole's then rivet or steel screws
Feb 12, 2009 | Bosch DKE 9365 Stainless Steel Kitchen...
Am buying a Bosch cooker hood - does it come with filters?
filters required only if you are venting inside your house (ie recirculating the air), if it is going outside, then you don't need them.
Jul 26, 2008 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Extractor hood
Unfortunately NO, use the template provided. Please ensure there are no cables running through the walls before you drill.
Aug 07, 2007 | Bosch DKE 9306 / DKE 9302 / DKE 9307...
Kitchen Ranges Logo
42 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
