How can I check the water level tube is blocked? Do I need to open the back of the washing machine?
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
MNTECH
  • 1543 Answers
SOURCE: lg wm2277h has low water level
The water level is very low on front load machines. (Below the bottom of the door) While the washer is running, push and hold the "spin speed" and "soil level" buttons at the time. Display should be between 230 and 255.(normal) If you do this while the machine is filling, you will see the numbers change. This machine only uses about 12 gallons of water for an entire cycle, vs. about 45 for some top loading machines. THIS IS NORMAL ! The machine will adjust the amount of water based on the type and volume of clothes in your washer. On a large load, you will see wet clothes, but no water sloshing around. PS. Because the machine uses so little water, make sure you use only one tablespoon of HE detergent (and only one teaspoon of fabric softner if you use it). This is very important.
If this info was helpful, please rate it as a "FixYa". Thanks.
Posted on Oct 01, 2008
  • 24 Answers
SOURCE: Maytag A512 Leaks out airgap when draining/spinning out
Check pump. I would say it is the most likely cause for the water leak, especially if itdoes it while filling and on spin as the pump holds some residual water in it . That is normal.
Posted on Oct 08, 2008
  • 106 Answers
SOURCE: water keeps running through washing
At what height is your exit hose. It should be approximately 3 feet up from the ground and then into the drain. This is rule one for all washers, it cannot be at floor level - your water will just flow out.
Posted on Mar 15, 2009
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Posted on May 05, 2010
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
Water keeps filling and overflowing when turned on but will stop when turned off, how can I fix this?
Could be a faulty fill switch. The fill switch is often an air pressure switch. As the tub fills a small internal air pressure is created which is sent to the switch via a small hose that sometimes becomes blocked or displaced.
If not it is possibly a fault with the control board.
Aug 01, 2016 | Washing Machines
Fisher
several reasons --tap not turned on---- solenoid that controls the water valve is burnt out--- and the water level control is registering full all the time.. Check that the tap has not been turned of---check that the little filter in the hose at the tap end is not blocked---change hot to cold hoses and see if hot water solenoid works. disconnect small tube to level controller and see if it opens the water solenoids.
Jun 23, 2013 | Washing Machines
Washing machine says it does not have water supply, the water is not hot
the level measurement may be blocked. At the back there should be a small pot connected to the drum by a tube. if the tube is block
ec then it won'tdetect that there is enough water to turn the heater on
Oct 15, 2012 | Hotpoint-Ariston Washing Machines
Water won't shut off on fill
There may be something blocking the pressure tube which measures the water level. This is a tube which runs from the bottom of the drum up to the water level sensor. Disconnect the tube at the drum and check, also blow in the tube and check the water level sensor is working, it should make a clicking sound.
Jul 06, 2011 | Maytag PAV2300 Top Load Washer
Washer water level fills past capacity and over flows
if the water is not shutting off - then the problem is a blocked ' water level sensor tube ' or a bad 'water level sensor '- - - remove the back panel of the machine and you will see a small plastic tube that is connected to the outer drum,, remove this plastic tube and clean and clear anything that might be in there -- if the line is clear, then the problem is the sensor itself,, check the wires to the sensor and make sure they are connected,, if all looks good - then remove the sensor and take it down to your local appliance repair shop and buy a new one and install it into the machine,, hook everything back up and test the machine --- all should be good to go.
c...
Feb 04, 2011 | Kenmore Washing Machines
Door can not be opened cos the spinning function does not work
Check the water level switch. If the tube is blocked, than the membran inside can't see the pressure. pressureswitch1.jpgIt's looks like this. Some machine's have more than one and some have more contact's which means that they can measure more than one water level. In most cases you have to take off the top cover of the machine to locate it. Take off with care the tube and blow towards the pump to remove a block.
To test the water level switch you need a multimeter in resitance Mode ( Ohm) to measure the contacts of the switch. If you gentle into the switch you can hear when the membran switches the contacts - on the multimeter you should see a change ( 0 if contact is closed - 1 if the contact is open). If nothing happend then the switch is faulty and have to be replaced. DO NOT TURN THE SEALED SCREWS on the switch. I hope this could help.
The picture is copied from this website : www.acmehowto.com/howto/appliance/washer/check/waterlevel.php
Nov 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
Starting a wash, tub overflows and keeps filling...
Sounds like there's a water level sensor problem. The water level sensor works by reacting to the air pressure in a tube connected to the tank. You need to open up the control panel. You may need to remove some screws, but on some machines you can "pop it" by prying it up with a putty knife. You'll find that the water sensor is the back of the knob that controls the water level. If it's a digital machine the sensor will be somewhere else but connected to a clear plastic tube. The first thing you should check is to unplug the tube from the sensor, and blow in it to make it's not just clogged with lint. If the tube flows freely, you'll need to replace to the water level sensor. This is pretty easy to do.
Dec 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 80 Series- Washer does not fill up with water before it starts washing.
Check if the volume of water supplied to the washer from the water line through the hoses attached to it is good. If yes, the screen inside the water-inlet valve if it is clean. If clean, the water inlet valve is defective and you need to replace it. The water inlet valve is located inside the washer on the upper back portion. It is where the water supply hoses are attached to.
Nov 07, 2009 | Kenmore Washing Machines
Nec nw452 washing machine water level does not stop. It overflows even when I put it on low level load. I keep having to turn the machine off and bail the water out into the sink.
I have just fixed this issue on my machine. Empty the machine by using the program options to spin only. Turn off power. Remove the plastic back plate then the silver back plate. Looking at the rear of the machine bowl, right hand side is a plastic tube which runs to the top right hand side of the machine. This is the water level sensor tube. Check if it is broken or blocked. Mine was broken near the top of the machine. I removed the lid (becareful to take note how the spring fits in with the leid for when you replace it. Remove the control panel cover. I saw the water level sensor (looking from the rear of the machine) to the right. It is brown and has one connector which needs to be disconnected (red and white connectors). Then the water level sensor is removed from its housing by unclipping the two clips. Once removed I replaced the tube and then put it all back together.
Jul 07, 2008 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
