Question about LG Washing Machines
My washing machine LG - model # T7517TEPT0 is displaying PE error - please advice to enable to fix the repair
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
PE stands for locked rotor meaning the motor is not able to turn either electrically or physically
Posted on May 01, 2017
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Hi i have a lg washing machine wft8061dd,can u please tell me why PE appear when it turn on
Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch. It is rare to see this error code on LG washers.
On non-display panel models this fault code can be shown by the lights for fuzzy, heating and speedy or super, normal and hold being lit or flashing.
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
Jun 13, 2016 | LG Washing Machines
Pe sensor error on lg washing machine
The best way to do is to call an LG service center regarding this problem.
Feb 01, 2014 | Washing Machines
Error PE on model wm2016cw, is this an easy fix?
Error Code PE mean Pressure sensor Error code
Check wiring connection to the pressure sensor; to solve it replace pressure sensor. The sensor repair is simple and straight forward.
Additonal details could find in this link: LG_Knowledge_Base
Hope this helps.
Aug 02, 2011 | LG Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
PE - LG Washing Machine WFT7012EN
I am finding a PE error as I try to use my washing machine this morning. Is there any quick fix for this?
Apr 28, 2008 | Washing Machines
Washing Machines Logo
52 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
