Question about Sewing Machines
Husky lock 36th model needles gold top - Sewing Machines
2 Suggested Answers
  • 11524 Answers
SOURCE: Husky lock 36th modeloverlock
what's your question?
Posted on May 01, 2017
Husky lock 936 cover stitch troubleshooting
try a new needle
try rethreading that one needle
rethread the looper
if that doesn't help, then the machine may have a timing problem and would have to be checked
Jun 10, 2015 | Husqvarna Huskylock Computerized 936
Why is my husky viking 170 skipping stitches
The most common cause of skipped stitches is a bent needle; the hook is not meeting up with the needle so a connection isn't made between bobbin and top thread. Try a new needle. If the skipping is consistent and a new needle doesn't help, it might need to be timed (call a tech).
Jun 15, 2014 | Husqvarna Husky 170
Husky lock 910 handwheel jammed
You will need to have it serviced by a Viking Service Tech. You can find a dealer near you by using the link 'Locate a Dealer' at the Husqvarna Viking Website -
Jan 08, 2014 | Husqvarna Huskylock Computerized 910
My Husky Mega Quilter is making a loud noise in the bobbin area. The noise increases in volume and intensity the faster I sew. At very slow speeds the sound is absent. I thoroughly cleaned and oiled the...
Perhaps Husky could help you, online. They Really want satisfied customers, and Huskys a Great machines!
A quick fix might be to change your needle. Even a slightly bent needle could cause havoc in the bobbin area. Hope it helps. Needles cost more that they did back in the day, but that sound is bad for your machine!
Jan 27, 2018 | Singer 14SH654
My needle wont sew on my husky star 207?
change the needle--make sure it's the right needle for the fabric
being sewed
rethread the machine top using every thread guide
check to make sure the bobbin is not over wound, make sure the
bobbin is not warped, & that the bobbin is inserted correctly into the
make sure the thread has not come off the thread take up lever
it's also possible that the machine is out of time
Jul 14, 2012 | Husqvarna Huskystar 207 Sewing Machine
I have an old Singer sewing maching, black with gold letter/graphics housed in a wooden base with a removable locking wooden cover. The serial number is AK631257. I can't find a model number. There is...
Chances are it will be the needle in the wrong way round or the wrong type of needle, if you can measure the length of the bed of the machine the metal part, tell me if the bobbin drops in the top or goes in the side and whether or not it is a round bobbin or long bobbin and I can tell you the model and help you further.
Aug 05, 2011 | Singer Sewing Machines
After taking only a few stitches, the bobbin thread becomes tangled and knotted. I've cleaned and oiled the shuttle and cover and adjusted the tension, but it still happens. Advice?
have you tryed changing the needle?
have you tryed changing the thread on top & bobbin area?
some thread & needle are not compatable--here's a tip I learned from a sewing expert
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
hope this helps
Oct 12, 2010 | Husqvarna Husky 145
I have a husky lock 234D serger and no manual. how do i use 3 thread overlock? which threads do i use?
To use a 3 thread overlock, thread the overlooper; the underlooper and then use ONE of the needles. Removing the RIGHT needle will produce a 5mm or 1/4" seam. Removing the LEFT needle will produce a 3mm or 3/16" seam.
Dec 17, 2009 | Husqvarna Sewing Machines
Husky 145
Usually when a machine is totally jammed, it's either (a) because a bunch of upper thread has gotten jammed into and around the bobbin assembly so thoroughly that the assembly can't turn at all, or (b) the needle is jammed down the hole so thoroughly that nothing moves.
If both of those places are clean and empty. . . then "Never mind!"
May 01, 2008 | Husqvarna Husky 145
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
