Question about Craftsman Garden
How to hookup the shifter cable from front to back on a drm 500 craftsman rider
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,025 Answers
Check out SearsPartsDirect they will help
Posted on Feb 04, 2018
2 Suggested Answers
SOURCE: need to rout a belt
Posted on Aug 01, 2012
My rider craftsman model 917280083 the deck sits too low it drags the ground even at the highest settting
most craftsman have a bar that goes from the deck to the front of the frame that raises or lowers the deck in your case you will want to tighten it up to make the deck higher.
May 02, 2017 | Craftsman Garden
Owners manual
Parts enter model make and what you want you can find one
Oct 10, 2016 | Craftsman Garden
Yard machines rider mower would not go back or forward, speed gears not engaging
Yard machine mowers are notorious for the shifter linkages getting bent or loose, it sounds like it's not engaging correctly and that you may need to get under it and see if anything is loose or obstructing that linkage. I know mine has that issue every season, the first thing I do is get under there and make sure everything is good to go, I tighten up the linkage and then I check the tension on the belts.
The next time you fire it up, push the clutch in all the way, apply gentle pressure to the shifter for forward and back, and then let off gently on the clutch until it pops into gear and begins to move. If you can't get it to do it that way, then I'd say you need to replace the drive belt or adjust it.
Sep 28, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 2000 Sportsman 500 RSE. I dont seem to be able to shift into reverse. The shifter moves freely from Neutral, to Hi or Lo, and the Neutral Green indicator light will light as expected, but the...
remember on early models there was a safety pin that had to be held to switch to reverse,,,your 500 does this automatically so check for safety pin hookup. Could be brush or
grass jammed in where it moves.
Dec 25, 2017 | Polaris ATV
I was told that my parking brake on my 2002 Kia Sedona is not engaging properly, though there is good tension on the line. I've replaced the rear drum brake pads, and adjusted the parking brake cable that...
Cable may be seizing in the sheath due to corrosion. Remove the drums to see if shoes move outward when someone pulls the lever. If not, remove the cables from the shoes, raise the ends, and shoot oil into the sheath. Break the cable loose inside the sheath and continue oiling until the cable moves freely in the sheath.
Aug 12, 2017 | 2002 Kia Sedona
Craftsman rider wont stay running
Once having the same problem with the B&S engine, I had to replace the ignition coil. When it is in the process of failing, it acted as you describe.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
You first need to locate the model number on the mower, not the Briggs engine. Then go to and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
May 25, 2009 | Craftsman Garden
Rider mower won't go forward or back
Ihave craftsman Lawn Tractor was cutting grass and it stop moving forward or backward. Can you help me
May 16, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman rider lawnmower
i have a rider 48inck cut and i need to know how to put the upper belt on
Apr 04, 2008 | Baby Gear
Garden Logo
59 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
