Question about LG Audio Players & Recorders
Whenever em turning ma lg dvd volume high it only say s protection and music stopped playing , what's wrong?
  • LG Master
  • 5,326 Answers
Check all your speaker wiring. Plus make certain the speakers are in good working order, and that low ohm speakers are not connected to it. For example if the unit says 8 Ohm, don't connect 4 to 6 ohm speakers.
If that doesn't solve the problem there's a fault in the main power amp.
Posted on May 03, 2017
SOURCE: Protection mode keeps kicking in
This happens less often in "normal surround" mode
Posted on May 05, 2007
SOURCE: Disappearing sound, Low sound, no sound
Unplug the system from the wall and plug in again...It worked for me...hope it works for you too.
Posted on Oct 05, 2007
  • 38 Answers
SOURCE: need help
Have you connected an extra pair of speakers?. (Thereby loading the amp stage beyond it's capacity)
Are the speakers connected to the unit the original ones the system came with or different? ( Speaker impedance, usually displayed at the back of the speaker cabinet must not be less than amp's specifications....6 ohms, 8 ohms)
If you're driving the unit excessively you're lucky this piece is equipped with protect mode, else your speakers and amp would have been fried by now.
One last possibility comes to mind: High volume causes vibration causing loosely fitted mains plug to rattle in wall socket calling "protect" due to improper feed voltage. Move the unit to another wall socket and ensure a tight fit into mains receptacle.
Posted on May 20, 2008
  • 1512 Answers
SOURCE: Protect Mode With Sony str-de595
Hi snark63
Ypou have an intermittent problem that sounds to be heat related... the more work the amp does, the more heat generated by the output stages. This will be aggravating some poor solder joints that are cracked or dry. The unit needs some repair work done in these areas. If you have good experience with a soldering iron, the cure for this is to resolder the power stages of the unit, or any other solder joints that look to be failing.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jul 06, 2008
  • 631 Answers
SOURCE: my pyle amp keeps going into protection when i turn my music up and play it for a min
The most common cause is an unsafe load/speaker impedance. If you have the speakers wired correctly, you may have a short in the wiring. If the wiring is OK, the amp is likely defective
Let me know if you have any other questions.
Posted on Oct 14, 2008
I have owned an NAD 705 Receiver for many years, and am just now having problems (probably over 20 years old). I'm getting a message on the screen of the receiver that says 'protection' .
if the receiver turns on and operates then eventually turns off due to protection mode its because a wire is shorting out the receiver.if it doesn't turn on or goes straight into protection mode then its probably time for repairs or a new receiver.
Jan 06, 2018 | NAD Audio Players & Recorders
When I plug my headphones in why doesnt the sound come out of the headphones?
Where do you plug in the phones? if it is an iPhone. the music playing will be stopped, just to precent your ears to be damaged. When plugging in headphones, while the volume is high, the sound level can be so high, you can damage your ears. Yes damage that will last the set of your life, because loss of hearing, can't regenerate. For that reason some MP3 played, cill stop music playing, as soon as a headphone is plugged in.
Just start the music that was playing when you did lower he output volume if the music stops.
Jun 29, 2014 | Computers & Internet
Well i was driving one day and my subs just whent out so i bought brand new wires and hooked everything up but the power protector light turns red whenever uu turn it up past volume 10 i really do not know...
It sounds like your amp is going into protection. I know it's frustrating, but this is actually a good thing. If you subs you have are drawing too much power and the amp can't keep up, it will shut off instead of melting the board. Usually, the protection mode only last a few seconds. The user normally turns the music down that the protection shuts off and the music plays again. I recommend looking at a larger amp for your subs, if you are going to play them that hard.
Aug 14, 2011 | Car Audio & Video
When i play music there's no sounds the media volume is in max and it is not in silent mode.. but when i connect a headset the sounds works fine... Whenever I try playing music on my LG Optimus S Sprint...
check the settings of the player of your.the output must have been just unmute.if that is not it goto to download mp3 and mp4 player install it and use it
Feb 03, 2011 | Cell Phones
Whenever I start playing on my xbox or playstation, the receiver will shut off (the red light is blinking around the power button). Once I hit the button, it stops and then I can turn the receiver back...
does it only shut off on high volume or a loud noise?
It's the amp tripping to protect itself.
look out for a shorting speaker wire or faulty speaker etc. disconnect each in turn to find out which
Sep 03, 2010 | Denon AVR-987 Receiver
Suddenly, amplifier stopped giving out sound. Controls and display seem to work fine. If it is blown fuse, where is it & how can i replace it?
Does it stop on both channels? It sounds to me like the safety circuit is activating. This usually happens when either the volume is too high, or the speaker load is too great (i.e. usually loads less than 4 ohms will do this) or, the amplifier has an internal short causing the amplifier's output stage to become un-balanced. Does the sound come out nice and clearly through both channels? How long does the receiver play before the sound stops? How loud are you playing the music when it stops like this? If the sound is reasonably clear through both channels at regular volume, then there is probably nothing at all wrong with the receiver's output circuits. If the amplifier is being played at regular volume or even lower volume for quite a while and then quits, perhaps the receiver is getting too hot and it's thermal sensors are activating the protection circuit. Make sure that when you operate the receiver, that there aren't things laying on top of it blocking the unit from venting and cooling properly. Make sure it has plenty of breathing room - amplifiers (most of them anyway) are inherently subject to producing heat. If the amplifier only quits when played at high volume, well then that's probably the problem - it's probably not meant to deliver such power that you're asking it to - especially if you're driving a heavy load such as 4 ohms or less. If you're running several speakers on this unit, try scaling back to just two speakers for now, and make sure these are 8 ohm speakers. Play the unit for a while and see how it does.
Oct 24, 2009 | Aiwa AV-DV95 Receiver
Samsung eternity wont play back sound
I had a problem similar to this a few times and found that it was due to the phone thinking that there was still something in the headphone jack so the only sound that would come from the phone was a ringtone or when using the speakerphone. To fix it you can plug in and unplug your headphones (while playing music) until the external sound playback comes back. Hope this helps!
Jun 08, 2009 | Samsung Eternity Cell Phone
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
Kicker CVR 10" "stuck"
sounds like the wiring in the speaker from the factory is shoty. rare but does happen. if you bought this from a retailer and have all of your warranty information id send it back and let em fix it
Mar 03, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Power & protect
my amp says Lo on the digital circle on top of the amp i have a mtx 9500 bridged to the amp and it cuts out at high volumes and suddenly please help
Dec 21, 2006 | AudioBahn A8000V 400W x 1 Car Amplifier...
Top LG Audio Players & Recorders Experts
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
