Question about Blenders
Fuse for blender120c
From where can I get 120c fuse for blender
    New Friend:
    Problem Solver:
  • 7 Answers
Blender 50246
If your blender has a separate fuse other than the one in the motor winding, it is most likely located inside the base.
Aug 13, 2014 | Hamilton Beach 50246 Blender
Fuse blew on my Oster BCVBO7 blender. Can it be
replace the fuse with the same specs. if it blows again, there is a short on the circuit.
Aug 22, 2009 | Blenders
KitchenAid Blender KSB5WH3 flashing lights how to get to the fuse
i found broken solder connections on triac on circuit board. it's the part with the cooling fingers that surround it. pencil soldered the cracked connections; now works fine.
Jun 19, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
My Waring blender fuse burnt out. Where do I find a replacement?
It's not a typical fuse, it's a thermal protective fuse. Looks more like a diode. They sell them a Radio Shack. You'll have to use crimp connectors to replace because a soldering iron will ruin it.
Apr 29, 2009 | Blenders
Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
HOW DO I REPLACE THE FUSE ON AN OSTER BLENDER MODEL 4094
unplug it.... use a small plastic screw driver or even a metal one if you are careful... pry gently up on one side of the fuse... it should pop out of the holder. when it does... use your fingers to grab the end and pull up. the fuse is replaced by placing it back into the holder and pushing down until each end pops back into the holder
Apr 11, 2009 | Oster 4093-8 Osterizer Classic Blender...
Lost blender fuse
There are no service manuals available for this model. If you can figure out what fuse it takes, Radio Shack most likely has them. What are the specifics?
volts
amps
watts
It can be figure with the electrical information. You will still have to get the right physical size though.
Feb 12, 2009 | Oster 6854 14 Speed Blender
Received the Breville Ikon 600 blender as a Christmas present in 2006 and have used it 3 times, with the third time being this past weekend. The product is now out of warranty and low and behold, it...
My IKON 600 Blender fuse had blown. It was located on the circuit board and can be found by removing the bottom of the blender. Fuse is Fast Blow 10A, metric 5mmx20mm. The fuse blew because the bearing in the bse of the jar froze. Bearing # 608-RS. The beraring froze because the seal in the base of the jar was leaking. Solution: Clean seak surfaces, replace bearing and fuse. Total cost of $6 with my labor.
Apr 16, 2008 | Breville CBL10 BlendMaster Classic Work...
Thermal cut off fuse replacement
I worked for sunbeam and they were 10amps there. dont go to high because u start a fire ..also while you replace it look for darker or blacking field wires..all wires should look good. but hard to start a fire when u got your finger close to off the button at most it will do is slow down and stop ...smoke...time for new blender then. CrazyLarry
Jun 03, 2007 | Cuisinart CBT-500 SmartPower Premier Work...
Blenders Logo
192 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
