Question about Westinghouse Washing Machines
We have a Westinghouse wsf6606x the water wont drain and keeps coming up with f2 error. didn't get a manual
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Check the water pump to be sure it is not blocked. Most commonly coins
Posted on May 01, 2017
Kenmore elite h3 front load washer is not working error code f2 flashes
The F2 error code mean that the washer didn't drain the water within the normal time it takes to drain,usually the reson the washer hasn't drained properly is because the filter screen on the drain pump is clogged with debris. this tip i have written will show ya how to clean the filter on the pump.
http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
GENE
Oct 08, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
What does the F2 Error mean? I got that error thsi morning. The engine was buzzing so I turned the power off. I have cleared what appears to be calcium and/or soap build-up in the 3 filters and in the...
The F2 error means the tray underneath the unit has filled with water. You will need to pull out the dishwasher (remove 2 screws at top left/right when door open that prevent tilting). Unplug and pull out dishwasher. Remove 4 screws on bottom rear panel and you will see tray underneath. Sponge out water and F2 error will reset.
However, you should not get water in this tray. There may be a faulty valve, pump or leaking pipe. Run diagnostic mode (described in user manual) to see if leak occurs during filling, draining or circulating.
Sep 19, 2010 | Asko D1876 Dishwasher
Drain pump keeps running and F2 error
This is caused by the "anti flood" system being activated. Consists of a polystireen float and micro switch at the base of the washer. Once water leaks / spills are detected it activates and puts the washer in pump out mode only. You need to dry the base / check for leaks / rectify leaks (normaly a small hole in pipe or pipe clamp).
Apr 03, 2010 | Asko 24 in. D3350 Dishwasher
Westinghouse LF708B washing machine wont spin,drains but wont spin Use to work when you thump machine but now wont spin at all
I have found that it is a blockage I manually drain the water through the botton of the machine then the cycle continues as a short term fix. I am not a professional though
Mar 09, 2010 | Westinghouse Washing Machines
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Jan 03, 2010 | Whirlpool Washing Machines
ERROR CODES ON MY WASHING MACHINE
join todays crowd!!! im in the same issue it is f2 error thatfollowedf suds error huh?
f2 is long drain issue after 8 minutes occurs anf the water valves to machine can be not fully iopoen; unplug ist
next keep off 2-5 minutes tpo clear memory
replug in
check drain hose not kimked
check drain pump inside is the next issue for prom is filled with foriegn objects that is known for this unit!!!! their a tech online kctech thats great try his answer online to use a shop vac and **** out any water in the inside and the hoes: and the drain pump inside the machine: see solution #6 may 2008 posted by washer gut in knasas that is eceptional to follow great day danw.
Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Wont drain error 3
check filter - try putting drain hose down at floor level and see if water runs out freely. if not, filter ius blocked. if water comes out freely, you may have a foreign object in drain pump. remove filterand see if you can see it. you will have water everywhere!!
Mar 26, 2007 | Hoover AAA160 Front Load Washer
Washing Machines Logo
411 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mack Baxter
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
