Question about Electrical Supplies
Generator won't idle - Electrical Supplies
    Sergeant:
    Habit-Forming:
  • Electrical S... Expert
  • 170 Answers
What generator do you have?
Posted on May 04, 2017
    Top Expert:
  • 26,762 Answers
Generators don't idle. They aim for maximum revs until the voltage regulator has enough voltage then it reduces the throttle.
Posted on May 01, 2017
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
9000kw winco generator
varying load causes varying operation...= normal
i.e: generator reacts via voltage regulator to compensate amp draw.
Mar 01, 2014 | Winco Hps 9000 Ve 8000 Watt Tri Fuel...
Why will my miller 250 will not idle down
There should be a selector switch where you start the machine. If you have this switch selected to idle and it still doesn't idle down after a few seconds of unloading the generator then you probably have a short in the switch tricking the generator into thinking it's under a load. Any spike in amperage or load will cause the generator to idle up.
Nov 03, 2012 | Miller Welding Tools
My Makita G5500r power generator doesn't have smooth Idle?
sounds like the carb needs to be cleaned inside any fuel the was left in the carb goes bad and it never runs it all out
Sep 06, 2012 | Electrical Supplies
Ranger8+ diesel will not weld or generate.
Check for proper placement of all springs & linkage on carb / throttle. One of those springs and/or linkage pieces is largely responsible for idling UP the engine so that it will be able to operate the welder & generator. If it won't idle up, it won't work right.
Aug 09, 2012 | Cars & Trucks
My coleman generator idle does not go to low idle when there is load on the generator it has idle control.
I could not understand, it doesn't go in low idle when load is connected or no?
It should go to low speed idle with load under 20 - 30 W.
Jul 10, 2010 | Coleman Powermate Premium Plus 6250W...
Generator doesn't excite with small power tools.
Somewhere on the Generator is an Idle Control switch, turning this to the off position will stop the generator idling down in the first place. You'll need to do this to use tools that don't draw enough current to trip the idle control system into revving the engine.
It may say just how much current you have to draw in the manual (hint, hint).
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Engine missing
Get a DMM that can measure frequency (Hz), then check that with no load and the idle control set to off the frequency is 61.5 Hz - If it isn't you have to troubleshoot why it isn't and correct it.
You should also check the idle control mechanism if there is one on the generator, with it on the generator should start up at regular speed, then slow to idle speed, then rev back up to regular speed when you draw current from the generator. To check it use the DMM to measure the speed at startup ( should be 61.5 Hz), when it idles down (about 37 Hz), when you're drawing power from any other outlet ( pretty close to 60 Hz). If the generator has idled down and you shut off the idle control it should rev back up immediately.
Please rank my solution,
Carl
Oct 03, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
