Question about Coffee Makers & Espresso Machines
Looking for an on off switch for an Einhell dsc 201 grinder. Durban
How to change the blade on my einhell lawnmower
turn it over and look at the blades . that might help you figure it out .
Jul 14, 2016 | Worx 17In Electric Lawnmower By
Model EH8804. Where can I get a replacement switch?
That is a specialised switch as it looks oval and is a three position switch on, off reverse. It _may_ be a standard switch underneath and the button is separate. A new grinder is only 40 bucks here
http://www.heartlandamerica.com/savoureux-pro-liner-meat-grinder.html
If you take it apart, you may be able to ID the switch on these images?
http://www.bing.com/images/search?q=replacement+switches&FORM=HDRSC2
Mar 10, 2016 | SAVOUREUX PRO LINE Meat Grinder
Looking to replace obsolete switch on Craftsman 1/2 hp bench grinder. Sears lists part as 4984992
This switch is a very close fit, and it is rated for 20A 120VAC.
2LNA7 $11.09 / each
Grainger
I've used it on that vintage Craftsman bench grinder.
http://www.grainger.com/
Dec 12, 2015 | Craftsman Grinders
Were can I get a on off switch for sears grinder mod 397 19581
Grainger 2LNA7 $11.09 / each
20 A/120 VAC
I have used this switch on that model od Craftsman grinder - 397.19581.
It is the closest fit, but not an OEM look. It is a red rocker with black base.
Oct 08, 2014 | Grinders
On/off switch-replacement?
Try Sears replacement parts department
Aug 19, 2014 | Craftsman Grinders
Switch Broke
I don't know about the switch going inside but you can contact baratza and they will send you a new knob that won't fall off for free.
Nov 25, 2008 | Baratza Maestro Plus (G385) Electric Burr...
Burr grinder GVX212
I had the same problem, took it all apart, separated the two halves, and looked into the guts of the machine, not an easy task. Fiddled with this and that, and looked at the back of the switch mechanism, and heard it making a 'click' when depressed, so put it all back together, to no avail...It turns out the grinder needs to have two limit switches engaged, one between the lid of the ground coffee hopper and the underside of the grinder hopper housing, and the other between the grinder lid and the base of the unit. This last limit switch was my problem, it seems the lid wasn't making contact with the limit switch, so the unit didn't run. I cleaned out the narrow gap that the grinder lid sits within, pressed the lid down until I heard a small 'click' , pressed the on switch, and presto! it works. You can see this very tiny switch if you take off the grinder lid, and look in the narrow gap it sits in at a position of about three o'clock ( the back of the machine when viewed from the top being 12 o'clock. Hope this helps anyone else who can't find their receipt within the one year warranty period. This is the best burr grinder I've found for the money, and I'm glad mine's still o.k.
May 20, 2008 | Krups Burr Coffee Grinder
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
