Question about Ricoh Office Equipment & Supplies
Ricoh 5002sp error add toner and sc396
Ricoh 5002sp error add toner and sawing error sc396, new developer not initialize
    Habit-Forming:
    Scholar:
  • Ricoh Expert
  • 129 Answers
Drum motor error;
The machine detects a lock signal error from the drum motor for 2 seconds after the drum motor turned on.
  • Overload on the motor
  • Defective drum motor
  • Defective harness
  • Defective IOB
Try removing the drum and turning the gears.
Posted on May 03, 2017
SOURCE: Add Toner
Tou can disasemble each pcu BK, cyan, magenta ,yellow ., at the back of the drum is 2 rollers the rubber one is the charge roller and the coloured one is the charge roller cleaning roller , take out the charge roller and wash it with soap and water , take out the cleaning roller and vacuim it out , be carefull not to dammage the drum .make sure that the charge roller is completely dry before you but it back .
Posted on Nov 18, 2007
SOURCE: Add Black Toner Msg.
Thanks Ricohman for the suggestion. Toner was original Ricoh cartridge and reinstalling it didn't help. I decided to tear the machine apart and discovered the auger for the black toner was stuck. I removed the auger, cleaned everything up and put the machine back together. Works great now.
Posted on Jul 14, 2008
SOURCE: add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Posted on Oct 26, 2008
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
  • 398 Answers
SOURCE: ricoh aficio 2035 keeps telling me to add toner
a part in the the toner hopper assy had the mylars come off, blocking the toner from going into the developer assy. P/N A2327263 (cover toner supply) I have seen this lots. -Carl
the p/n is for USA model.
Posted on Jul 10, 2009
Loud toner error
The machine does not use the toner directly from the bottle, it goes thorught a developer chamber filled with developer powder. Then the toner is charged and can "jump" over to the latent image of the drum.
In this developer chamber, there are some small gears (2-3 tiny gears) that may be worn out. Some developer may have entered the "gearbox", and the deveoper powder is very abrasive.
The teeth of the gears will eventually stop to contact and mesh up. The internal parts of the developer changer stops to revolve, and there is no toner mixed with the developer.
You can see that there is a build up of toner, but it does not enter the developer unit. These gears have to be replaced, and I allways change the developer powder at the same time.
mp 2000 developer gears-2rhlv5r3sdqqpeuzs0ozcjtp-5-0.jpg These gears must be replaced it they are worn. The image shows a brand new part that contains the gears.
mp2000 developer toner input side-2rhlv5r3sdqqpeuzs0ozcjtp-5-1.jpg This is the side of the developer unit where toner enters the developer unit. With defective gears, the developer unit can not pull toner inside of the unit, and the toner builds up in front of the unit.
The gears are cheap, but will often result in the need of new developer powder - and that is expensive.
If print quality does not have to be too good, one can use the old powder and save money. Some of the powder is lost during use, and leaks. There may be some dust in the developer too.
In order to get high quality several parts may need to be replaced.
It is quick and easy to change these gears, just a bit dirty job.
Jun 24, 2017 | Ricoh Office Equipment & Supplies
How do i fix problem Add Toner
The Ricoh has toner and developer. When the developer is depleted it can not get to the right density when toner is added so the machine keeps saying to add toner. You need to clean out the developer unit and put in new developer. Depending upon your model you may need to install a drum and blade too. Ricoh technicians are trained to dissemble the unit and just replace the parts needed instead of getting a whole drum/developer unit. If you live in Southeast Florida Advanced business computers is a great source for help. Computer network repair, printer and copier maintenance repairs, leasing and supplies.
Oct 28, 2015 | Ricoh Office Equipment & Supplies
RICOH MP 3350B ask for toner even having a new one
Take out the toner cartridge and shake it vigorously. When they sit for a long time the powder tends to clump.
Nov 19, 2014 | Ricoh Office Equipment & Supplies
Ricoh afficio 1045 & ricoh 450 toner is mixed in ricoh fw 780 now background and negative image is coming what can i do plz give some idea
firstly you need to remove the developer and vacume the developer unit and magnetic developer roller.
Put in new developer and correct toner in toner unit.
Call service...
After replacement there is a sequence wich needs to be done, for developer initialization.
Aug 16, 2011 | Ricoh FW 780 Black and White Copier
What can correct an SC392 on a Ricoh MP W2400?
SC392:Toner density sensor initial setting is not performed correctly.
  • No developer
  • Developing roller does not turn.
  • Development roller coupling gear is not correctly attached.
  • Poor connection of PCU
  • ID sensor defective
Source: Ricoh Errors
May 06, 2011 | Ricoh Office Equipment & Supplies
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 03, 2011 | Ricoh Office Equipment & Supplies
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
Adding developer to the new ricoh aficio mp 1500
Apr 10, 2009 | Ricoh Aficio 2015 Copier
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
141 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
