Question about Jamo Audio Players & Recorders
Jamo E850 speaker bass units access remove front panel screws
  • 1462 Answers
SOURCE: door handle
removing the front panel is just meccano. the screws are probably torex - a driver is easily available from any tool shop
Posted on Mar 26, 2007
  • 1990 Answers
SOURCE: need to remove window crank 2004 hyundai accent
Your Local Auto Parts Store has the Tool that you need for this Removal. Some of them will let you Rent it instaed of paying the 50.00 Bucks for the Tool.
Posted on Jan 24, 2009
  • 6 Answers
SOURCE: Replacing speakers in Mitsubishi Galant
If the car is an 03 galant it is very simple to remove.
Remove the window crank if it is not Electric Window.
Remove the Screw that holds the "Open Door Handle" cover.
Remove the Screw that holds the "Pull Handle Pocket"
Remove both plastic covers.
Remove all 3 hidden crews that have a plastic cover over them.
One is toward the front of the door top and the other two are toward the rear of the door top and bottom side.
Carefully pry around the door trim panel to disengage it from th retaining clips, along the sides and bottom. If you have electric windows, disconnect the if from the door trim to access the speaker. Same procedure for both doors.
Posted on Mar 03, 2009
  • 42 Answers
SOURCE: 1991 Nissan Maxima: Removal of front driver side door panel
This is out of my haynes manual
1 disconnect negative battery cable
2 on manual window equipped modesl remove the window crank using a hooked tool to remove the retainer clip.
3 on power window equipped models pry out the armrest switch control plate and disconnect the electrical connections
4 detach the armrest pull handle retaining screw then remove the inside door handle trim bezel
5 insert a wide putty knife, a thin screwdriver or a special trim panel removal tool between the trim panel and the head of the retaining clip to disengage the door panel retaining clips.then remove the remaining door panel retaining screws at the lower edge of the door panel.
6 once all of the clips are screws are disengage detach the trim panel disconnect any electrical connectors and remoe the trim panel from the vehicle by gently pulling it up and out.
7 for access to the inner door remove the door panel support bracket then peel back the watershield taking care not to tear it. it install the trim panel first press the watershield back into place. if necessary add more sealant to hold it in place.
8 installation is the reverse of removal
Posted on Mar 20, 2009
SOURCE: speaker removal instructions for 2002 grand vitara
You need to take to whole front door trims off, the rear speaker grills just pop off.
Posted on May 23, 2009
Need schematic diagram infinity basslink subwoofer
Design: The BassLink brings together a 10" subwoofer (treated paper cone, foam surround), a 10" passive radiator (to increase efficiency and limit distortion), and an extremely efficient, specially designed 200-watt Class D amplifier that work as an integrated system. Special circuitry monitors voice coil position to maintain linearity at high power levels, so you hear loud, clear bass.
Enclosure Type and Materials: The enclosure is made of an acoustically inert polymer which is rigid enough to resist flexing and dampens any resonance.
Servo-Control: The servo-control system continually monitors the performance of the speaker and ensures that the amplifier delivers exactly the right amount of power.
Class D Amplifier: This unit has a built-in 200 watt Class D amplifier which is highly efficient and designed specifically for use with the subwoofer and passive radiator combination.
Auto Turn-On Feature: When the speaker level inputs are used, the system will automatically turn on and off with the radio. Note: The auto turn-on feature does not operate when the preamp level inputs are used, unless the remote turn-on lead is connected.
Low-Pass Crossover: The low-pass crossover frequency can be varied from 50Hz to 120Hz for a seamless transition between the output of this unit and that of the other speakers in the vehicle. The crossover has a slope of 12dB per octave.
Bass Boost: The amplifier includes a continuously adjustable bass boost from -6 to +3dB centered at 40Hz.
Phase Switch: Allows you to select normal or reverse for best bass.
Mounting: You will be able to put BassLink in a variety of in-vehicle locations, thanks to its compact size and mounting feet that enable the rigid polymer box to be mounted vertically or horizontally.
Vertical Mounting Dimensions:
Width: 14.625"
Height: 13.375" (including feet)
Depth: 8.675" (10.076" including feet)
Horizontal Mounting Dimensions:
Width: 14.625"
Height: 9.5" (including feet)
Depth: 12.75" (15.1875" including feet)
BassLink LC Remote Level Control
Overview: The BassLink LC allows you to adjust the volume of BassLink powered subwoofer.
Installation: The BassLink LC may be mounted under the dash or may be dismantled and mounted inside the dash for a factory appearance.
Under-dash Mounting: Select a mounting location that allows easy, safe access to the control while driving. The BassLink LC has mounting "ears" to use as a template for drilling pilot holes. Attach screws through the "ears" to secure the BassLink LC to the mounting surface.
In-dash Mounting: Disassemble the BassLink LC by removing the Phillips-head screws on the front, rear, and top panels. Remove the bottom and side panels and disengage the RJ11 connector from the back panel. Choose a mounting location that allows easy, safe access to the control, and provides 1-3/4" clearance behind the mounting surface. Drill a 9/32" hole in the mounting surface. Feed the BassLink LC's potentiometer (with the knob removed) through the hold and use the nut provided to hold the control in place.
Connecting to BassLink: Route the cable behind the dash or other interior panels and under the carpet. Do not route the cable outside the vehicle. Connect the cable on both ends.
Inputs and Controls
Universal Interface: Front and rear, left and right Universal interface speaker-level inputs (for use with the supplied speaker-level input wiring harnesses)
Line Level RCA Inputs: Front and rear, left and right female preamp level inputs
+BATT (+12V): Gold-plated screw terminal, 0.350" wide
REM (remote turn-on): Gold-plated screw terminal, 0.350" wide
GND (ground): Gold-plated screw terminal, 0.350" wide
Fuse: There is an installed 20 Amp fuse
Remote Gain Control: Phone type jack for included remote gain control
Gain Control: Rotary control that sets gain (variable from 250mV to 4V)
Crossover Control: Rotary control that sets the low-pass crossover point (variable from 50 to 120Hz)
Bass Boost Control: Rotary control that sets bass boost level (variable from -6 to +3dB, centered at 40Hz)
Phase Switch: Selects normal or reverse phase (0 or 180 degrees)
Power LED: The power LED glows red when the BassLink is on
Servo LED: The Servo LED glows green when the servo circuit has determined that the woofer has reached maximum excursion and power to the woofer has been modified to provide maximum performance. The LED should light momentarily during high-level bass transients. Note: Avoid adjustments that cause the LED to remain lit for an extended period of time
Apr 01, 2012 | Infinity Bass Link Subwoofer Car Audio...
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
Dec 01, 2011 | Jamo Audio Players & Recorders
I have a pair of Jamo Laser 2000P speakers, and the rubber support for the bass units is perished. Where can i find the correct replacements?
I can't find any data to indicate the size of the speaker but if you search eBay for "(speaker size) foam surround" you will find various kits.
Apr 14, 2011 | Audio Players & Recorders
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
Apr 11, 2011 | Jamo SUB 200 Subwoofer
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
My jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
Feb 08, 2010 | Jamo SUB 200 Subwoofer
Cuts in between on higher volumes & higher bass levels
Sounds like the subwoofer speaker is broken. Opening the subwoofer is difficult, and frankly the effort is not worth it, as the quality of this system is very poor.
Nov 14, 2008 | Logitech Z-340 Computer Speakers
Just got a jamo A3SUB.3
check all your plus sign and minus sign that connected to the receiver , if connected wrong you will not have any bass,because it going backward. Good luck!! any quest email me
Dec 25, 2007 | Jamo D 4SUB Subwoofer
Is there any way to take these apart?
If there are no screws evident on the rear of the unit carefully remove the grill on the front. Usually they are just lightly glued on. Most quality speaker enclosures open from the front and the speaker can be taken out for access to the wiring inside. If you cannot find any way in from the front look for some sort of plug or cover over screws. This could be on the back or under the grill. Sometimes they are covered with plastic covers which match the surface. If you do not have access any of these ways this could be a sealed unit which is not made to take apart. Good luck.
Jun 25, 2006 | Cambridge Soundworks Center/Surround IV...
Top Jamo Audio Players & Recorders Experts
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
