Question about Samsung Refrigerators
I need to replace veg drawer rail how Samsung srf model French 3 door
3 Suggested Answers
SOURCE: water build up underneath deli tray drawer
Ok. I know why this is happening. Or at least in my case.
The coil for the Fridge is stored behind the center panel when looking directly into the the Fridge.
What happens is the drain for the coil becomes iced up. It then wont drain and when the fridge goes into defrost mode the melted water will run out of the bottom of the center panel. This is difficult to see due to all the shelves in the way. i noticed this because I could see ice through the vent holes in my center panel.
To fix this:
Take all the items out of the fridge.
Take all the shelves out so the center panel is exposed.
Remove the 3 screws at the bottom of the panel and single screw under the cover of the shelf rail. (This one is a little hidden) pop off the plastic cover first.
Now you can pull the panel off.
(Note. This can be a little difficult to get off because you have a ton of ice behind there keeping it stuck to together. Just ease it off as much as possible.
When you get this off you'll most like see alot of ice in the tray that the water is draining into. chip this ice away and then I used Hot water to pour into the drain. I would then use a shop vac to **** the water out and put in more hot water until the ice plug is removed and the water can flow freely to the drain pan under the fridge.
That is it. I own this fridge and I've been tired of having to **** water out of fridge with a shop vac every 2 weeks. So I decided to resolve this myself.
*disclaimer. I'm just a DIYer not a Samsung repair person.
Good Luck and I hope this solves your issue.
Posted on Aug 25, 2012
SOURCE: samsung rf265 series french door
I have the same problem!!! We need a class action lawsuit against Samsung for this problem on their French Door fridge. Instead of fixing it they want the consumer to pay for repair. NO MORE SAMSUNG PRODUCTS FOR ME!!!!!
Posted on Jun 01, 2013
How do you replace a freezer drawer front?
The freezer drawer front is held onto the glide-out rails with screws on either side. These will be 10mm. Once the screws are removed you can lift the drawer front up and off the rails.Be careful when replacing to keep both left and right rails the same distance out from the cabinet so that they close evenly.
Sep 28, 2016 | Samsung 28 Cu Ft Black French Door Bottom...
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
Aug 23, 2016 | Samsung Refrigerators
Samsung refrigerator
The moisture has to be getting inside to pool. Check your door seals or leaving the doors open to long.
Aug 14, 2016 | Samsung RF265AA Bottom Freezer French Door...
Bottem freezer drawer rails
You need a service manual. My refrigerator is a different model. A diagram for installing the freezer tub rails or other installation of the parts might be found in the service manual of your unit. You can check the availability of the service manual from Samsung's authorized parts distributor. You can get this information in two ways - online and by phone. Have your model number ready for either option. You can order the manual over phone by contacting Samsung's parts distributor, Samsung Parts, (also known as J&J Parts) at 1-800-627-4368. Hours of operation: Mon - Fri from 9:00 A.M to 8:30 P.M EST.
Nov 02, 2014 | Samsung RF4289HARS French Door...
Samsung rf266aepn bottom french door ice maker arm
Simple but a pain. Unplug the refrigerator. Get out your hair dryers and start de-icing the freezer door. Slowly but surly you will get freezer open. Be gentle. Dry EVERYTHING!!! Tracks, rails.....then replace part, plug back in, restock.
Oct 12, 2013 | Samsung RF266AEPN
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
Water in the fruit and vegetable draweres
You might have the frig. temperature set too low. Set it at 38 deg. check actual temp. with gage. What happens is ice builds up in the drain tube that runs down to the bottom when the fridge defrosts therefore causing water to run into the veg. drawers. Ice buildup is preventing the water from running out at the bottom where it should. Just raise your fridge temperature a little and the problem should go away. Hope this helps.
Feb 04, 2013 | Samsung RF265AA Bottom Freezer French Door...
I cant get the cool select pantry drawer back in
I just had the same problem. The drawer was removed for cleaning and we could not get it back in; it would slide in with about 3 inches not able to go in. Took everything out that we could and still could not get it to go back in all the way. Finally started looking closer at the metal rails and the sides of the drawer and realized there is a tab on each side that needs to be inserted in the the corresponding hole on the metal rail. With the drawer out, pull the rails all the way out; place the side rails of the drawer on the metal side rails and line up the tabs with the holes and insert. Your drawer should now slide in correctly.
Dec 18, 2012 | Samsung RF265AA Bottom Freezer French Door...
Samsung rf265 series french door with freezer drawer on the bottom: Water collects under the veg drawers in the refrigerator part. What might be wrong?
Sep 04, 2011 | Samsung RF265AA Bottom Freezer French Door...
How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
Dec 14, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
