See below pic captured...score strip of left is hiding on my samsing dnie jr tv..plz help me wit making screen normal...same happens while watching news.....
techman
  • 3130 Answers
SOURCE: Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Posted on Sep 12, 2006
SOURCE: Picture size too large
We have the same problem with the same model. We already had the main board replaced. The picture has gotton so bad that you cannot adjust the pixels anymore. Well, you could never get to the pixels that were off the screen because the picture is too big
Posted on Jun 28, 2007
  • 6 Answers
SOURCE: Toshiba 50A50 missing sports score on top of image
Download the service manual and you'll find that there's a service mode that allows you to adjust convergence. Also, there's some adjustment knobs behind the right front speaker assembly
Posted on Oct 22, 2007
ctf1800
  • 4402 Answers
SOURCE: Toshiba 50A62 blurred screen
does it look like these?
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
  • 15 Answers
SOURCE: Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Posted on Apr 14, 2009
My samsung DNIe Jr CRT colour tv has the picture problem. When iturned it on, few minutes colour of screen varies to red and normal mode. What may be the reason, how can I rectify it.
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jun 03, 2016 | Samsung Televison & Video
Is Samsung plano DNIe Jr 21 inch a flat TV model; kindly confirm
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 25, 2015 | Samsung Televison & Video
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
Aug 13, 2014 | Samsung Televison & Video
Is samsung Dine Jr supports ps2 games
Assuming you're referring to the Samsung DNIe Jr, then yes, it will support displaying the output of a PS2 console on it's screen. You may need a RCA+Composite to Coaxial Signal Modulator to convert the PS2's signal Composite and RCA output to standard Coaxial-Compatible input though, depending on the ports your TV has.
Mar 28, 2014 | Video Game Consoles & Games
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Horizontal screen size
will probably have to take to service center. will need to get into service menu and nedd serive diagram.
Mar 10, 2008 | Daewoo DTQ-25S3FC 25" TV
RCA 27" Colortrak T.V.
Your vertical height needs to be adjusted or you have a capacitor that needs to be changed 100uf 35v, 1uf 50v.
Dec 25, 2007 | RCA F27242GY 27" TV
Cant read espn scores
same problem...screen seems to be to long. i cannot see all objects on bottom...no solution in the menu...help plz
Dec 07, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
