Question about DeLonghi Coffee Makers & Espresso Machines
Delonghi coffee machine red light keeps flashing even after descaling
SOURCE: After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Posted on Feb 02, 2009
  • 1089 Answers
SOURCE: the red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
Posted on May 21, 2009
  • 8 Answers
SOURCE: I have descaled my Saeco Odea and the coffee beans
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Posted on Feb 13, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
Red light keeps flashing all the times
Witch red light?
Could be that the red light telling you to descale the unit is flashing.
if so then you have to descale the unit...see manual
Oct 05, 2016 | DeLonghi Espresso And Cappuccino Maker -...
Delonghi magnifica has exclamation
Switch the machine off, AND pull the plug, wait 5 minutes (to be sure) and turn it on. Then turn it off again, now the infuser should return to it's normal position where you can take it out.
If the descale button is still flashing, try descaling again. Was the procedure interupted before? That would be a reason the light keeps flashing.
Bert
Nov 19, 2015 | DeLonghi Coffee Makers & Espresso Machines
My delonghi ec860 red light keeps blinkin when coffee finishes coming out what does that mean.
Robert is it the light that has two signs underneath, if so then it is time for descaling.
kolbrun
Jan 23, 2015 | DeLonghi EC860 Silver Espresso/Cappuccino...
Flashing coffee and descale
Identical problem, descale light doesn't extinguish despite descaling correctly. Coffee continues to be made as normal though ! Any solution ideas please ?
Mar 04, 2013 | DeLonghi Coffee Makers & Espresso Machines
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The CLEAN light has come on. How do I clean it?
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
Dont know what red light is flashing for because ive lost the ins
hello the red ligth is flashing, because to much coffee or u need to clean the machine cleane with sal and liqued soap thanks
Feb 24, 2009 | DeLonghi EAM3200 Espresso & Coffee Maker
Coffee Makers & Espresso Machines Logo
195 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
83bj60
Level 1 Expert
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
