Question about The Office Equipment & Supplies
I have an old Bauknecht dishwasher 4741that has been great for years that now keeps stopping after the first rinse.
It has started to stop after the initial start phase and I have to restart it a few times by pressing and holding the start button so it goes back to the beginning. Then if I am lucky it sometimes works.
SOURCE: Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Posted on Apr 08, 2007
SOURCE: Whirlpool ADP951 Dishwasher
Processor board sound bad. May be a loose plug ( or corroded connection on the plug ) . Unplug the dish washer from the wall plug before servicing. The open the front panel to expose the panel control board. Unplug the panel plugs and inspect them to assure no corrotion is apparent. If you see corrotion, use a pencil erracer to clean all contact points on the board and clean the plug the best possible. Plug the dishwasher plug back in the wall and check the unit for proper operation. If the operation is not correct, replace the circuit board. I hope this helps
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Dishwasher starts then stops
My (KUDI01TJ)Dishwasher did the same thing.
I Pressed start, it acted like it was starting and then turned off.
I started the rapid advance service diagnostic feature:
1.Close dishwasher door "Hi-Temp Wash" "Energy Saver Dry" "Hi-Temp Wash" "Energy Saver Dry"
This started the diagnostics and the dishwasher went through each cycle.
After this, my dishwasher worked fine.
I think the controller must have got in some wierd mode and unpluging the washer would not clear it out but running the
diagnostics cleared it.
Hope this works for you
-Steve Payne
Posted on Aug 19, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
Bauknecht gsf 4481
The timer is not advancing to the next cycle. Replace the timer.
Mar 13, 2014 | Bauknecht Dishwashers
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Hi my Bauknecht GSI 5411 dishwasher seems to starting ok but then it stops after a couple of minutes. have checked the water supply tap as well as the filter and they seem to be ok. Please help
Set the machine to the end of the drying cycle, when it has finished, try pouring boiling water into the machine about a kettle full there is a sump level control beneath the removable filter (where all the **** gathers) if this has fat deposits on it this type of problem can occur.
Nov 05, 2009 | Bauknecht 24 in. GSX7551 Built-in...
My Kenmore dishwasher starts to fill and then stops
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Oct 04, 2009 | Kenmore Dishwashers
My Bauknecht dishwasher stopped working
Check all your breakers. Remove the wall plug, count to 20 and plug it back in and count to 5. This will reset it.
Jul 17, 2017 | Bauknecht 24 in. GSFP3988 Built-in...
have only worked on them a few times but no problem to use. literally select program, close door and start. you won't break anything by trying it out.
put detergent in the dispensor and rinse aid in the rinseaidv despensor. if in a harrd water area, add dishwasher salt to the softener
Aug 14, 2008 | Bauknecht 24 in. GSF8971 Built-in...
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Feb 08, 2007 | Bauknecht 24 in. GSFP3988 Built-in...
29 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
