Question about Tablets & eReaders
W/fi keeps shutting down on its own - Tablets & eReaders
Asus tablet is locked out of wifi
Go into settings, turn off Wi-Fi, shut tablet down and wait a couple of minutes then turn back on. After boot up go back into settings turn Wi-Fi back on and see if you can connect to Wi-Fi. If not then the Wi-Fi part of the tablet is probably defective.
Feb 24, 2017 | ASUS Tablets & eReaders
I keep getting errors saying "this browser is no longer supported". It says connected to wi-fi. Help??
Have you tried updating your web browser or checking for updates in the drop down menu at the top right?
Mar 23, 2015 | Double Power Nobis NB09 9" 8 GB Wi-Fi...
My Tablet keeps shutting down, uses Battery quickly, won;t even find wireless, when it stays on long enough.
You neglected to provide the age of the tablet. If it's a couple years or older your battery might be on the way out. They don't last forever and some of them aren't of the best quality to begin with. Charge it all night long. In the morning when you turn it on if it still doesn't work right be sure to check the battery level with the A/C adapter unplugged. The level indicators are based on the voltage. If the voltage doesn't come up to spec, it might show less than 100% charge even when charged overnight.
The wi-fi problem could be battery related, too, as wi-fi is a radio transceiver that sends as well as receives signals. Wi-fi doesn't work so well if the transmitter produces a weak or intermittent signal.
Mar 08, 2015 | Ematic 7" Touch Screen Tablet
How do I shut down my motorola zoom MZ604 tablet? It keeps restarting.
Try safe mode first: Power the Device Up in Safe Mode Motorola XOOM . this helps To eliminate third party apps as the issue.
If that doesn't help then try How do reset my Motorola XOOM to original settings .
Motorola Support
Feb 28, 2015 | Motorola Mobility Xoom MZ604 32GB Android...
Why won,t ipad connect to wifi , keeps saying not connected but was 2hours prior
are there any other devices connected to the same wi fi are they working ?
TRy powering down wi fi router
Feb 20, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Chromosome inc tablet keeps kicking me out of games and it looks like there is a plane icon in my WiFi icon
your device is in airplane mode and when it tries to look for inet connection that is shutting you down. shut off wi fi or airplane mode or both and you will be ok.
Dec 17, 2014 | Tablets & eReaders
Acer iconi b1 thermal warning
why does my acer iconia keep saying Thermal warning and shutting down when I have only just switched it on?
Nov 26, 2013 | Acer Iconia B1 7-Inch Tablet Black Dual...
I'M not able to connect to any Wi-Fi on my Nabi 2 when I scam for Wi-Fi signal it doesn't give any options to choose from I have a router which I'M able to connect it to my laptop and my tablet. I was...
My kids are always turning on "airplane mode" which shuts down the WiFi. Be sure the tablet isn't in airplane mode (you'll see an airplane icon) in the settings. (It's also an option at shut-down.) Being in airplane mode would prevent the Nabi from "seeing" the WiFi devices.
Sep 12, 2013 | FUHU 7" Tablet PC NABI2NV7A
Tablets & eReaders Logo
49 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
