Buzzing saniflo Not working but buzzing
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Faint buzzing noise, no pumping
which mosel is it? here is a site that has a phone number to call, since I DON'T HAVE THE MODEL NUMBER I can't give you more informaiton. also need to know if it'sa add on system and if it's above floor pump system or if it's the pump in the gray water tank system.
http://sanifloproducts.com/
Mar 17, 2010 | Saniflo Home
My saniflo pump has stop working, what can be wrong
Have you got power to the pump? .. if it is on a fused spur, check that there is power (i.e. check the mains switch board)
Jan 17, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Macerator
unfortunately saniflo - nor any one else publishes a saniflo repair manual. You can get tips online - but thats as far as it goes.
Dec 10, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
My saniplus macerator has stopped working. The 240volt feed going to it is ok.
does it make any noise? the valve switch may no be working. if you hear the motor buzzing but not working, something is jammed in there. either way, be ready to get your hands dirty.
Nov 13, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
When flushed pump starts water goes but pump keeps running when level is reached
pump keeps running - again this is indicative of a dirty / scaled saniflo. You need to clean / descale the saniflo. if this does not work then an outlet pipe blockage (22mm) may have occurred (unlikely if the unit is operating ok). Saniflo sell their own cleaner, which can be introduced via the wc bowl. If this does not work, then its time for a proper clean ( remove unit, jet clean, acid descale, wash, replace). Obviously not everyones cuppa tea.
Oct 27, 2009 | Saniflo & Saniplus& Macerator Pump
Sanishower operated for short time and then just went to a buzzing noise - first time operation - any suggestions
It needs cleaning out regularly - at least once a year! We have one fitted to a shower that is used daily. The small amount of hair - that falls out every time hair is washed under the shower - builds up and clogs up the pump. We are on our second pump, the first installed just over 10 years ago, this one is under 3 years old and it already looks like it will have to be replaced.
Mar 03, 2009 | Saniflo & Saniplus& Macerator Pump
 Grubhead
Grubhead
