Remote Control for Model No.: SSTDS22B1
JNC 22"LCD TV HDMI Nicam
SOURCE: My Polaroid TV model not listed, it's TLX-04240B
I got the 42" Polaroid HDTV from Walmart (on Black Friday) and was able to link it to my Tivo remote using the Mitsubishi setting and code 0001.
1. Tivo Central 2. Settings
3. Remote Control 4. Part 1 and then Part 3
I use it to Power On/Off and Volume control.
Posted on Mar 11, 2008
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
free2rhyme
SOURCE: need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Posted on Mar 25, 2009
  • 6 Answers
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
Posted on Apr 20, 2009
  • 5059 Answers
SOURCE: Looking for replacement remote for Venturer 22
Try here: http://remotes.com/remotes/servlet/rs?a=Search&mode=brand&v=1&brand=Venturer&uuid=A12605685976201
Posted on Dec 11, 2009
Testimonial: "WOW - Answered in just a few minutes of posting. Thank you Cindy."
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
Mono stereo function
Tv Speaker; Stereo/dual Reception; Nicam Reception ...
www.manualslib.com > ... > Flat Panel TV > 141K TX > Owner's manual
LG 141K TX) Manual Online: Tv Speaker, Stereo/dual Reception, Nicam ... Stereo. Dual. Mono Sound Selection. In stereo reception if the stereo signal is weak, ...
Video Mode; Audio Mode; Still; Stereo/mono - ManualsLib
www.manualslib.com > ... > LCD-32CA9S > Owner's manual
Dec 21, 2015 | Televison & Video
Tv says format not supported for my blu-ray disc player
Hmmm, interesting a tv with hdmi that does not recognise the format. Check the player on another tv first to make sure it is working correctly. If it is then check the hdmi settings on the tv in question to make sure that all settings for hdmi or the same as the tv it works on.
Jan 11, 2014 | Philips 22PFL3505DF7 22 in LCD TV
I have a 22" Westinghouse
Change the settings on your HDMI output to 720 progressive for resolution. The tv likely cannot handle the 1080 resolution, or the tv can only use interlaced (1080i or 720i) format.
Aug 21, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
How to connect laptop to my coby tv?
Check if you have an HDMI or VGA/DVI port in your LCD TV and LAPTOP. Once you have those ports you can just buy an HDMI cable or VGA/DVI cable to plug it to your laptop.
Jan 31, 2011 | Coby TFTV2225 22 in LCD TV
Just tried to hook my aoc 22" to high definition
I beleive you have to enable audio in the HDMI SETUP so it will send the digital audio through HDMI ports, check the cable box and the TV HDMI sound setup.
Nov 19, 2010 | AOC L22W861 22 in. LCD HDTV
Playstation 3 will not come on screen when I connect hdmi cable to tv. tv not recognizing hdmi. What do I do?
Try resetting the playstation and a hot swap. Turn off the tv and the playstation and remove the hdmi cable from the television. You should see a red standby light on the playstation. Press and hold down the power button until you hear two beeps. Now plug the hdmi cable back in. Turn the television on. Turn the playstation on. Hope this works.
Oct 08, 2010 | Sharp LC22DV24U 22 in. LCD TV/DVD Combo
WHY IS MY LCD TV CHANGING COLORS?
Check ur input tv signal?like it tight,if u use a HDMI cable.Replaced this HDMI cable.Not work after this.Than ur Main Tuner board is dead.Must replaced this board.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Apr 12, 2010 | AOC L22W861 22 in. LCD HDTV
Hi I am Tom. I have a new Coby TFDVD2274 22
Tom for your HDMI problem try hooking up separate audio cables to your tv if you get audio you probably need to change those hdmi cables.
Oct 16, 2009 | Coby TF TV1524 15 in. LCD TV
Cant play my xbox 360 on my 22 inch Insignia tv
Is the TV an High Definition TV?
If it's not an HDMI compatible tv them you will need a regular audio video cable for your XBOX 360
you cn get them all day on ebay or at any store.
May 25, 2009 | Insignia 22 in. Widescreen Flat-Panel LCD...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
