Sir, when I Right-click on any file then it take so much time to open or my right click is very slow.Plz help me.
  • Computers & ... Master
  • 5,660 Answers
Suggest you use a Registry Cleaner, and rid your harddrive of file fragments. CCleaner is a Free registry cleaner, and I will put it up against any of the paid versions. (No, I have no affiliation with CCleaner. I have used it for more than a year now, and I'm impressed
The Windows operating system uses a Registry.
Think of the registry like your local library. Now
remove covers off of some of the books, and the title page, and put the books in the wrong shelves. Some of the books even have pages torn out.
Fragmented files in the Windows registry is close to that. Fragments of files are left behind, and Windows has to sift through them to find the actual file needed.
The Windows defragment tool cannot possibly do as good a job, as a registry cleaner.
This is information about CCleaner on Wikipedia, and the next link is the CCleaner home page,
1.Information: http://en.wikipedia.org/wiki/CCleaner
2.Homepage: http://www.ccleaner.com/
Posted on Jul 25, 2009
    Sniper:
  • 163 Answers
  1. your pc have lots of applications installed remove those applications which are not in used.......
  2. used some better antivirus program may be your pc have affected with virus...and that's y your pc takes lots of time..
  3. click on the start button then click on the run or press ctrl + r
  4. then type temp and delelte all the files from there
  5. then again use the 3 number point which is return above and then type %temp% in it and delete all the files from there
  6. then again used the 3number point which is return above...and type prefetch then enter and delete all the files from there....
  7. or if you think that this process is typical for you so used ccleaner software....or speed up my pc software
  8. used the 3 no option from the above statement and type msconfig then click on the startup tab then click on the disable all and restart your system....
  9. and if the program still there format your pc bcz your system have infected with viruses.....
  • 70 Answers
Hi, this is most likely caused by a context handler in your right click menu. The next step is to find which context handler is causing the problem, Please follow the steps below.
Download ShellExView (from nirsoft.net) and run it. It will scan the registry for all the shell extensions. Once the scan is over and the list is displayed, you need to spot the context menu handlers. Sort the results using "Type", so that the context menu handlers are displayed together.
The trick is to disable non-Microsoft context menu handlers *one-by-one* and verify if the problem is solved. If disabling one does not solve the problem, undo the disabled item and disable the next non-Microsoft handler. Do the same until the problem is solved and finally identify the culprit.
Once you have indentified the culprit, uninstall the software or get an update to the software.
If you have any further queries, please do not hesitate to ask
Regards
Bytestream
Hi i have 16 gb transcend pendrive so i'm can't open and use that pedrive so what is the solution for my problem plz help me
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
if still no joy
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps you
Apr 08, 2012 | Electronics - Others
I cant format my mp3 player so plz help in and give me solution for this
Deleting Files,Pictures,Videos,Audio
Books, Apps,etc. from MP3 Player/Ipod
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release,right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
BE CAREFUL and do not delete files needed to operate your MP3 player.
This is a FREE answer, Please rate me
Apr 06, 2011 | Audio Players & Recorders
Sir my nokia E72 is running very slow from unlocking to all other applications.whenever i click on any application it takes mre time to get start.some time it stuck for 1 to 2 minutes.please give me...
Sir whenever i use internet on my Nokia E72, during opening of any website a warning message appeared ''Memory full.Close some application'' but there is nothing open at mean time.plz could u help me to solve this problem?
Thankyou
Dec 11, 2010 | Cell Phones
Computer slow when shut down slow takes about four minutes
Steps 1.Kimdly diasble the all startup function (opent the run command and type MSCONFIG and automatiocally open one window and choose the STARTUP and diasable the all function)
2.kindly delete the all temporary file(open the run command and type %temp% and select the all file and then press SHIFT+DELETE,Sir.
3.And also delete the all the prefetch file
4.and also increase your catch memory,Sir.
5.And also increase your virtual memory,Sir.
Right click over the mycomputer and choose the properties and then choose the advance tab and then click the setting below the performance and then again click the advance and then choose the virtual
memory,Sir?
Nov 22, 2010 | Compaq Evo N610C Notebook
Won't start up after shutdown. suggests disc check but freezes.eventually comes on after skipping dosc check,but running slowly
If you do not shutdown your system properly means,that time only it will act like that that means file checking.
memory,Sir?
Nov 17, 2010 | Acer Aspire One PC Notebook
My computer is very slow at downloading video i.e youtube
memory,Sir?
Nov 17, 2010 | Acer Aspire 5315 Notebook
I cant open my work at vista movie maker because ita MSWMM file, please help me sir
have you tried using a video converter! i can give you real good one! this might help unless the converter doesnt accept the file GL HF
So install the converter then the Plantmaster Msninfo document, right click the msn document and then open with word pad and use any of those serials !
http://rapidshare.com/files/327793687/Video_converter.rar.html
a link is posted to help assit this solution so plz i am sorry for the links!
Dec 30, 2009 | Microsoft Windows Vista Ultimate Edition
Plz tell me the cd key for cricket2007
2rbk-n522-8aw3-v8aj-5rld
after installing ur game
right click and open the cd there will be a folder named CRACK open this folder and copy the files in this folder
now right click on the cricket2007 icon on ur desktop and click properties then find target and paste the copied files in the window that will open up replace the files and click ok
now enjoy the game
Jul 01, 2009 | EA Sports Cricket 07 for Windows
My webcam icon not display
Hello SIr,
check whether u've installed the cam driver properly.
if so..then plz go to C:\Program files\ .... there u'll find the name of icon same to that of ur driver's name..
go into that folder, right click on webcam icon. then 'send to'..in that as " shortcut to desktop", then u'll find the Icon on ur desktop...!!
thank u sir..
if u feel that my response is wroth reading then plz vote me sir..!!
Mar 29, 2009 | Acer Aspire 4720 Notebook
Hard drives not accessible
first go to run inthe start column type in msconfig when it comes up go to start up and stop most of the programs that are loaded at startup leave only antivirus. as all programs will work in normal way as you need them
go to windows explorer c:\ right click\properties\tools\check now tick the box Fix errors reboot. On rebooting windows will scan file system for errors and fix them
Jul 12, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
