Question about Cell Phones
My phone is locked in safe mode. - Cell Phones
How do I start safe mode on an Android Coolpad 5560s?
  1. Check that the device screen is on, then press and hold the Power button.
  2. Tap and hold the Power off option in the dialog box.
  3. Touch OK in the following dialog to start safe mode.
Nov 12, 2016 | Android Cell Phones
Cant get my phone out of safe mode
How to get Android phone out of safe mode? I have a Sony ...
  • > Forum > Android Smartphones I have a Sony Xperia M. For some reason it got put into safe mode. I've tried switching it off and on again and holding in the volume up key like it suggests on the ...
  • How to Turn Off Safe Mode on Android : 13 Steps - wikiHow
    2016-02-04 · How to Turn Off Safe Mode on Android. ... This is the quickest way to get out Safe Mode if you have this ... select Restart or Power Off. Allow your phone to ...
  • How to Get Your Android Phone Out of Safe Mode ' Smart ... Is your android cell phone stuck in Safe Mode? Wondering how to turn Safe Mode off? Then here is the solution. Understanding Safe Mode. Before we begin, if you're ...
  • Easy - How to get out of Samsung Galaxy S "Safe Mode"! Medisoft > Tech > Samsung Galaxy "Safe Mode" Quick Dibb Solutions to get Samsung Galaxy phones OUT of "Safe Mode": Turn off the phone; Remove the battery for 10 ...
  • how do i get out of safe mode on my phone? ' Yahoo Answers > Computers & Internet > Security > Next
    • 7 POSTS
    2012-01-17 · Best Answer: If you hold both volume buttons, and the lock button at the same time when the phone is off, it should open up a menu and you should be able ...
  • How to take your Android phone out of Safe Mode! - YouTube
    • BY N??DII L?ON?SS
    • 4 MIN
    2012-07-09 · Video embedded · I was browsing through Instagram and my phone froze up, I took the battery out and turned my phone back on and when I did, my phone was in Safe Mode ...
  • Jun 29, 2016 | Cell Phones
    My power button is not working my phone was switched off could you pls help me to switch on my phone. power button is not at all working my battery is full and it was switched off.
    Sometimes plugging in the phone (into the charger) allows the phone to boot. Maybe your battery is simply empty? Charging the phone is a good idea regardless.
    Also, try booting to safe mode to test the power button:
    1. Turn "OFF" the Galaxy S6
    2. Press and hold the Power/Lock button at the same time until you see the "Galaxy S6? logo
    3. When the logo shows up, immediately hold the Volume Down button, while releasing the Power button
    4. Keep holding the Volume Down until your phone finishes rebooting
    5. If it was loaded successful, a "Safe Mode" will show on the bottom left corner of the screen
    6. Let go of the Volume Down button
    7. To exit "Safe Mode" press thePower/Lockkey and then touchRestart
    Dec 14, 2015 | Samsung Galaxy S6 Edge
    Motorola photon locked in safe mode
    If you power cycle the phone it will exit safe mode.
    Motorola Support
    Jul 24, 2014 | Motorola Mobility Photon 4g - 16gb - Black...
    How do I get out of safe mode on a Casio G'zOne Commando? I have removed battery for several minutes and power cycled the phone and still it wont do anything when i touch the screen and says safe mode
    power up, on the "gzone loading" screen hold down: power, volume up and the menu button ( soft key on far bottom right on the face) at the same timefor about 20 30 seconds and an option to reset screen which you use volume down to choose and power to confirm. a Android dude pops up with its guts spinning around and then the setup your phone thing starts
    Apr 26, 2014 | Computers & Internet
    How do i get my lg optimus gt540 off safe mode
    Keep it locked in the safe. Now it will be on safe mode.
    Aug 11, 2012 | LG Optimus GT540 J1
    HTC phone in safe mode, can this be fixed
    Hi, When you're done troubleshooting problems with your HTC Hero in Safe Mode,
    you will need to go through steps to boot it regularly and remove it from Safe Mode.
    To do so, turn off the phone. Then while its off, hold the Menu and Power until the phone boots. The Hero should then no longer be in Safe Mode
    Start the phone and uninstall apps in safe mode
    If your phone keeps restarting, or it starts up but does not display the Home screen, a recently installed application may be causing the issue.
    When this happens, try starting up your phone in safe mode. In this mode, your phone does not run any third-party applications. Safe mode allows you to start up your phone successfully so you can uninstall any applications that you have recently installed or which may be stopping your phone from starting up correctly.
    To start up your phone in safe mode, press the END CALL/POWER button and hold the MENU button until your phone restarts and displays the Home Screen. You will see "Safe mode" displayed at the bottom-left side of your phone screen. When your phone is in safe mode, follow the same steps in Removing installed apps to uninstall the third-party applications.
    After you finish uninstalling the applications, restart your phone and check if the issue is resolved.
    Hope it helped.
    Thanks for using fixya....
    Jan 10, 2011 | HTC Droid Eris by
    Keyboard is locked, looks like in safe mode.
    Compaq laptop keyboard is locked, looks like in safe mode. How can I get the keyboard to work???
    Jul 02, 2009 | Compaq Easy Access Internet Keyboard
    Cell Phones Logo
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
