Question about Photography
The water inlet flow into the machine is not stopping in the F65 Whirlpool white magic F/A machine, due to which it showing an FE error
Model F65 White Magic Suresh
  • Photography Master
  • 5,412 Answers
I know of no camera with a water inlet - have you posted this query in the correct forum ?
Posted on May 02, 2017
Lg model lds5540 smells, will not clean properly and doesn't seem to have enough water during cycle. also occasionally shows the fe error code. ??? any thoughts?
WATER OVER FLOW ERROR // Water continuing to enter machine
The manufacturer has assigned this error or fault code to indicate that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.You can check it with a multimeter to confirm, it should show continuity on both hot and cold pins. try exchanging the how and cold water hoses, cold on hot and hot on cold, see what happens. have u tried running only cold water or hot water wash? as for the smell could be a build up of detergent or frabic softner, try washer running machine with hot water and vinigar to clean out also check inlet valve for dirt build up
Dec 08, 2016 | LG Washing Machines
FE code on LG washer.
The FE code is an excessive water supply if the water is continuously running into the machine it may be due to a failing inlet valve or stuck float switch since you mentioned the drain pump filter being changed it could be that the old filter was restricting the flow.
Apr 28, 2015 | LG WM Washing Machines
Whirlpool Duet "wfw9200SQ00" error F30
Possible that there is clogging in the inlet filter or valve, remove the hose to the inlet and check the flow,
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Jan 24, 2013 | Washing Machines
P.c.b. not working
Washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.
Oct 21, 2012 | Whirlpool Washing Machines
I got PE error code in my whirlpool white magic F65
The PF error code indicates a power failure on many different machines. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 13, 2012 | Washing Machines
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
I hear some different noice along with slight vibration, when water filling in the washing machine. my washing machine model is Whirlpool F65 fully automatic one 2 one 2 wash. Its need any service?
Could the sound be described as a chatter / rapid clicking?
If so, it's probably the inlet valve for either the hot or cold water which is not opening all the way due to a dirty/malfunctioning solenoid valve.
Charlie
Aug 14, 2009 | Whirlpool Washing Machines
Whirlpool Washing Machine, Product- F65, model7234,water overflow
top loader?usually its because your water valve is not closing because minerals have gotten into the water valve.but water would come into washer even when unpluged.another thing can be if when over flowing and u unplug it and it stops fillig/over flowing.your presure switch hose will have come off the water level switch or a mouse chewed a hole in it.its a clear tube thats running from your water level switch.i hope that helps god bless,tom
Jan 01, 2009 | Washing Machines
Photography Logo
141 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
