I have completed a wash on 28 minute cycle and now the door will not open it keeps on saying wait for cooling
  • 1003 Answers
SOURCE: soap door won't open during wash cycle
Posted on Jan 18, 2008
  • 770 Answers
SOURCE: Washing Machine Door won't open
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
  • 351 Answers
its either the dispenser or the timer/pcb.
Posted on Mar 02, 2008
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 244 Answers
SOURCE: Broken door handle for a Thor washing machine
there r 2 ways to get the door open 1)use a normal knife and place in front of the door handle push it in and it should open 2)pull the plug out take the lid off now place your hand down to where the catch goes into the washer using your fingers u should be able to pop it open with a bit off fiddling
Posted on Dec 16, 2008
Tecnik Washing Machine 9290 Red light not gone out so not able to open door. I switched it off by mistake but put it on and did the whole cycle again but still on and unable to open door . Please help
from the manual always WAIT.
Use the handle to open the door.
During the wash and dry cycle, a special safety device keeps the door locked.
To open the door, turn off the machine using the ON-OFF push-button and wait about 30 seconds after the switching off the warning light before turning the handle to open the door.
WARNING: Set the cycle only when the machine is off. - Always turn the control dial clockwise. If you pass the desired position, make a complete turn and reset the dial to the
exact position.
Jul 25, 2016 | Tecnik Washing Machines
I have a hot point Hvl200 And the door won't open after the cycle and the door locked light is still on
You have to wait approximately ten minutes after the cycle has completed and door will unlock then
Feb 26, 2015 | Washing Machines
When the remaining time is one minute but wait for long time but can not open the door
The door locks need to 'cool down' after the end of the cycle. So with one minute remaining you will have to wait for the cycle to finish this minute and a further 2 minuter approx for the door to release. Thats how the machine is designed to work unless there is a seperate door release feature.
If there is you should find the instructuions in the hand book
Aug 07, 2010 | Washing Machines
F-28 flashing. Door will not open
While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
Check your washer plug to see if the connections are tightly screwed. You can also plug off for half an hour to reset.
How abt a nice rating for the free help? Thnks
May 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer, model c45092
in all cycle with seven min left washer, m-c45092 stop and door open no spin cycle. pete.
Apr 19, 2010 | Kenmore 45081 Front Load Washer / Dryer
Door won't open
Check your instruction manual to see if there is a childlock feature that has been activated.
Is there water in the machine or has it completely rinsed out?
If you switch the power off and wait a couple of minutes, can you then open the door with the power still off?
Sep 25, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
AEL Lavamat 509N
These machines do not release the door immediately after wash cycle is complete. After final spin cycle wait until you hear a click sound.The door will then be able to be opened. This takes uproximately three minutes.
Dec 04, 2007 | AEG Lavamat W1050 Front Load Washer
When the wash cycle is complete, the door doen' open?
the door may be locked electrically, pneumatically or mechanically. if you unplug it and wait 3 mins see if it opens. if not keep unplugged and check the door lock from the inside to see if there is a tube connected to it- if so pull it off. if no go the lock may be jammed.
Jun 07, 2007 | Supra SW5L50D Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
