After watching directv, I cannot get DDerect. It says no signa. What button did I push wrong.
Need to reprogram my remote to my Samsung tv. No manual
How To Program Your Samsung Universal Remote
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsFeb 5, 2013 - You can program your Samsung television universal remote control to... Note: Your remote may have separate buttons labeled Cable, DVD, ...
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote-c...
DirecTVHow do I program my DIRECTV remote control? Print. Email ... DIRECTV RemoteSetup to Change the TV Input Source. If you can ... Still need help? Contact us ...
HOW TO RESET YOUR TV REMOTE CONTROL - YouTube
? 3:15
https://www.youtube.com/watch?v=CnFfo8-3GC4
Feb 11, 2012 - Uploaded by SlimfromMrRemote
However, if this does not work and you do need a new TV remote,... thank you so much my control samsung tv AA59-00580A its working again ...
HOW TO PROGRAM SAMSUNG SMART REMOTE - YouTube
? 8:35
https://www.youtube.com/watch?v=asgS7NzQLi4
Jun 28, 2012 - Uploaded by Tampatec
Feb 03, 2016 | Samsung Televison & Video
How do i reset my dvr
If you stuck in CCTV DVR Password Reset process. just visit
CCTV & Networking Technical Support Channel on youtube.
Here is the link:-
CCTV Networking Technical Support
Jan 13, 2016 | Swann Communications Home Security
My signa E377 R/F watch wont reset to correct time.It,s 42 mins fast.I need instructions.Can anybody help?
Check you have the battery in the correct way and it is the right voltage/one for your watch
Apr 24, 2012 | Watches
I have had this TV for 5 years, it's been great. My wife and daughter just started pushing buttons a week ago and now the color settings are really messed up, just when I think it's correct, the is...
Reduce color level up to zero and check, does tv show black and white picture?
This will confirm white balance settings to narrow down problem section.
Oct 10, 2010 | Hitachi 42HDF52 Television
Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Sep 05, 2009 | Jacuzzi Signa Whirlpool Tub B540
Cannot return to TV from DVD play
If you have a Directv receiver, and you have to be on channel 3 on the TV to watch it, then we have to get you off the video input. On a Directv remote, there should be a button toward the top left hand side that says "TV input." Try pressing this first. If that doesn't work, then look for the button on the Insignia TV remote control that says "tv/video," "source," "input," or something along those lines. Press it (some TV's make you press it several times to change the input). Just make sure that your Directv receiver is on before you start pushing buttons.
Give that a shot.
Jan 06, 2009 | Insignia 19 in. Widescreen Flat-Panel LCD...
Hitachi Plasma will not remember what input to watch tv on
TURN THE TV OFF AND LEAVE OFF. TURN THE CABLE ON AND TURN THE CABLE OFF. LEAVE THE TV ON.
Dec 20, 2008 | Hitachi 42HDF52 Television
I have a magnavox dvd player and just had directv installed and I cannot get the dvd to recognize the directv channels. I can only record two digit numbers.
your best bet for this problem is to rearrange the way you have your direct tv and dvd hooked up to your television. a lot of the time you can plug the dvd player into the input/antenna in jack on the back of the receiver. that way you can watch all the channels you want AND be able to watch dvds without having to unplug and replug stuff in. more than likely you'll have to push an input or tv/vcr button in order to switch between watching direct tv and dvds, but it's a lot simpler than switching chords around.
Jul 28, 2008 | Televison & Video
Coby dvd 755 home theatre system hook to directv
The composite output (red, white and yellow) on the directv receiver should connect to the audio in (red and white) on the coby ht system. Then you have to select the correct input on the coby til you here the audio from the DTV receiver
Feb 10, 2008 | Coby DVD-755 System
Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Sep 09, 2007 | Televison & Video
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
