Question about Light Office Equipment & Supplies
Riso 200 ep master empty warning light remains on after fitting new master roll
  • 2777 Answers
SOURCE: Riso RP 3700 indicates that the master is still on
It honestly sounds like the unit is going to need some repair work. All the types of troubleshooting possible have been done by the looks of it. It's a hardware problem which is impossible to repair remotely.
You can call Riso at 978-777-7377 to find the nearest service center.
Sorry about that.
Thanks for your patience and understanding,
Posted on Aug 12, 2009
  • 17 Answers
SOURCE: need to know how to disable rf chip feature on Riso
Short answer: You can't. RISO designed it this way so you need to order supplies from them.
Solution: 1-800-942-RISO to order genuine supplies.
Posted on Mar 30, 2010
  • 34 Answers
SOURCE: Riso EZ 200E model gives error message A-34 -218
It means to reset the master material in the master making unit. Should be ok after that.
Posted on Sep 09, 2010
SOURCE: Minolta CSPRO EP 1080 isn't copying, shows only warning lights
I have a Minolta 1080 could be used for parts.
Posted on Sep 14, 2010
  • 55 Answers
SOURCE: riso 390U error code p19
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Posted on Apr 29, 2011
Riso rz 200 ep
I Think you are missing the ink, look for Wich ink you are missing
Jun 10, 2014 | Avaya Ethernet Routing Switch 5698TFD-PWR...
Master roll rz
yes but it is always good to use original consumables. plus if your unit is under warranty, you can ask for help with the company anytime.
Jan 22, 2014 | Riso RZ220 Duplicator
Problemas com riso rz 200 ep
error code d-02 -532
I think drum needs reprogramming
Apr 12, 2013 | Riso RZ220 Duplicator
I need an instruction manual for the Riso RZ 200 EP machine. Can you help please?
go to www. or or or
sincerely. God bless you
May 09, 2012 | Office Equipment & Supplies
I have the d17 error message. I did try to reset it but it still shows the error.
236 - incorect master roll
237 - master roll undetected
238 - master roll communication error
239 - wrong master roll detect
241 - detected a mismatch in master roll information
you must stop the machine and remove the cable from the print drum PCB and check that there is no ink on the connector or the PCB.
If there is no ink try to enter in test mode and activate 0890 test.
If it dose not work call for tech from Riso.
Dec 01, 2010 | Riso RZ220 Duplicator
Code D-17-236 The Riso just stop working, Why?
A D17 is incorrect master roll installed. This could be caused by a) it IS the incorrect master roll, or b) the RF tag that is inside the master roll has gone bad. Try a new one in the original packaging to help with diagnoses. Make sure they are RISO Z type master rolls specific for an RZ220.
Jan 21, 2010 | Riso RZ220 Duplicator
Riso RP 3700 indicates that the master is still on the drum halfway throught the master making process and shuts down. The master has been removed. shutting down the machine does not help. Rolling on a new...
Remove the roller on which the master has been created. That will force the machine to start a new cycle. Right now the machine has thinks its in between the cycle, so to synchronise both, its been told to remove the master. Switch it off & then begin again........sodeep
Aug 10, 2009 | Riso RZ220 Duplicator
Displaying A05-305
make sure that you empty the master disposal box...
also check for this sensor. if it is not present you will need to have it replaced
Jun 12, 2009 | Riso RZ220 Duplicator
Machine error Riso RZ 37 EP
Make sure you have taken all the master out the dispsal box, also make sure the senser is clean and there is no pieces of master stuck around the wheels inside the unit.
Nov 17, 2008 | Riso RZ220 Duplicator
41 people viewed this question
Top Light Office Equipment & Supplies Experts
Alan Tippett
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
