Question about Rowenta Irons
Rowenta dg8520 leaking from soleplate - Rowenta Irons
4 Suggested Answers
SOURCE: how do i clean the soleplate?
don;t open vido in real player
Posted on Apr 27, 2010
heatman101
  • 43501 Answers
SOURCE: my iron is leaking from the soleplate rowenta
Here is a tip that will help tou figure out your problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
ercupa190
  • 12223 Answers
SOURCE: Install new sole plate rowenta DMV 890
see the video and use the common sense and fix it. God bless you
Posted on Oct 16, 2012
The bottom of my rowenta focus has a burnt grainy film on it. How do I clean it and prevent it from happening again. I've only used it approx 4 times but it is over a year old.
Rowenta FOCUS STEAM IRON DZ5164 DZ5164U1 user manuals
will give their specific instructions.
Rowenta has a kit, including a paste cleaner for iron soleplates, available from Amazon.
Home made cleaners include a paste of baking soda and vinegar. Rub on, let sit, and wipe with a wet cloth. (Some add a drop or two of dawn dishwashing liquid)
Another home made cleaner is the Mr. Clean Magic eraser, thoroughly wet, and rubbed over the soleplate.
Make sure to wipe the soleplate with a clean wet cloth at the end to remove cleaning residue.
Clean your iron's soleplate while the iron is cold, and don't use something scratchy like a steel wool pad, to avoid scratching the surface.
Aug 11, 2017 | Rowenta Irons
I need a schematic for a Rowenta DW-8080 steam iron
They do not publish such diagrams for this type of product.
Oct 03, 2016 | Rowenta DW8080 Pro Master 1700W Steam Iron...
Leaking water around base
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
God bless you
Feb 03, 2013 | Rowenta Irons
How do you clean the soleplate? I have some residue/buildup that does not wipe off. I already did the self-clean to remove deposits but there is still "stuff" on the soleplate
You can use Rowenta Sole plate Cleaner. If you cannot find it locally, check online at retail sites like Amazon.
If you want to try a home made cleaner, Avoid abrasive cleaning powders or scouring pads.
Begin with a cold iron that is unplugged from the electrical outlet. Use a mild dish washing soap or laundry detergent to create a sudsy solution. Use a nylon mesh pad, sponge, or a clean cloth dipped in the solution to completely wipe off the soleplate of the iron. Wipe the soleplate clean with a damp cloth or rag.
If the soleplate is the victim of a starchy build up or corrosion of some form, you will need to use something a little stronger. Use a clean cloth dipped in white vinegar to remove the build up. Wipe the soleplate clean with a cloth dampened in clean water.
If this does not work, then you will need to heat a solution of white vinegar and salt until the salt dissolves. Using a clean cloth sipped in the heated solution, wipe the iron's soleplate clean. Continue wiping until you have removed all of the build up or corrosion. Remember to wipe the iron completely clean with a cloth dampened in clean water.
Let me know if you have any other questions. Thanks.
Read more: http://www.doityourself.com/stry/cleaniron#ixzz1L4J0N8Yh
May 01, 2011 | Rowenta DZ1700 Iron
The green arrow on the controll dial lights up,,there is continuity through the soleplate but there isn't any heat
If you are getting continuity from the plug to the soleplate (other than from the ground/earth pin), I would suspect the heater element is broken and is touching the soleplate.
Jan 10, 2011 | Rowenta DZ5080 Iron with Auto Shut-off
My iron is leaking from the soleplate rowenta actipress DM160 iron
heatman101
Jun 10, 2010 | Rowenta ActiPress DM160 Iron
How do you clean the DM580 Rowenta iron? It is
Here is a tip that will help you with that problem...
Cleaning a Steam Iron Soleplate
http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate
heatman101
Feb 06, 2010 | Rowenta Precision DM580 Iron
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Rowenta Professional DM890 Iron with Auto...
Irons Logo
114 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
