Question about Photography
What dongle is compatible with the "pan digital edge touch picture frame?"
  • Photography Master
  • 5,412 Answers
I doubt if there is one - I know of no such frame that will connect to the Internet.
Posted on May 02, 2017
I need to replace the battery in the remote. How do I open the remote?
The battery on the remote is on a 'tray" that can be pulled out. The tray is on the back of the unit, at the bottom. There is a click-catch that you need to squeeze while you grab the edge of the tray. Use your fingernail to hold/squeeze the catch laterally before you pull the tray out.
Make sure you replace the "button battery" on the try with the correct side up. Then slide the tray back into the slot and make sure it snaps into place.
Jan 02, 2011 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Every time i take a picture of a moving subject on my fuji s3000 digital camera the subject i have just took does not appear on the frame.or only partly in the frame i have tried on all modes even the...
try this photography technique called panning...
panning is when your shooting a moving object you need to follow that moving object while pressing shutter speed..this technique is the technique photographers to capture moving objects...Have you seen a picture that has a blurry background and focused subject (ex. cyclist) panning is used to create this kinds of pictures...try to search in google or photo sites about Panning
Jul 06, 2009 | Fuji FinePix S3000 Digital Camera
How do I get music into SV1011 digital Picture frame
There is no internal memory on your frame. Therefor you must transferre the music onto the SD card and then it will play from your frame.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Mar 09, 2009 | Kodak Digital Picture Frame
I need a manual for the pandigital 70-0 digital picture frame
I find that going to the manufacturer's web site and then going to Support usually gets me access to at least an on-line manual, but most often a downloadable manual.
Hope this helps.
Dec 16, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
I can't make my memory card work with my idf-1030 digital photo frame
Even though the card may fit the frame it still may not be compatable (if you are useing an SD card try a sandisk DS card they are very compatible with these frames
I hope i was of help!
Dec 16, 2008 | Polaroid IDF-1030 (826219006783) Digital...
I have a 10" frame. The picture that I take with my digital camera is cropped by the frame. It seems to crop about an inch off the edges. How can I fix this. I can alter the picture if necessary.
Depends...
if it's during a slide show, then there's a slide show option "screen fit or fill".  If you are set to fill then it will cut off edges, change the setting to screen fit.
or if it is cutting off all 4 sides when displaying a single photo, you may have the zoom turned on.  Tap actions / zoom and set the zoom back to 1x.
Dec 15, 2008 | Kodak EasyShare EX1011 Digital Picture...
Missing driver for pandigital photo frame
i have a i-disply 7'' lcd screen only memory card input but i lost the card so now if i insert any card it showing insert memory card. so please help me how can i use this if any softare required in the memory card , help me please
Nov 23, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Direct image feed to digital Frame?
I just did a fast lookup and heres one frame
http://www.onecall.com/ProductDetails.aspx?id=89172
You can take the memory card with the pictures out from your camera and insert it into the picture frame and instantly view all the pictures from the card on the picture frame.
Nov 18, 2008 | PANDIGITAL 15-inch Digital Picture Frame...
Pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Sep 09, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Photography Logo
144 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Are you a Photography Expert? Answer questions, earn points and help others
