Question about Nilfisk Vacuums
Where is thermal fuse on 540 nilfisk vacuum cleaner
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: nilfisk c120 vacuum - no power
The fuse is part of the motor so is not something that can be changed. Make sure that there isn't a break in your power lead at the plug.
Posted on Mar 19, 2009
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Why wont the reset button depress on riccar 8955 or turn on after trying
The reset button does not have a significant amount of movement in response to pressing to with a paper clip or ball point pen. If the vacuum does not start upon pressing the button, then either the thermal protection circuit is not why the vacuum stopped in the first place or the reason the thermal protection circuit tripped has not been cleared. Quoting from the manual
"Your Riccar vacuum cleaner comes equipped with a Manual Reset Thermal Fuse Protector. This thermal protector is designed to protect your vacuum cleaner from overheating due to a restriction in airflow (i.e. clogged hose, operating the vacuum without a bag). Should this situation occur, the thermal fuse protector will safely shut off the vacuum cleaner to avoid any potential damage. NOTE: To determine it was the thermal fuse protector that turned off your vacuum
cleaner, please refer to the vacuum cleaner's headlight. If the headlight is on while the motor is off, then the thermal fuse protector did safely shut down the motor. If both the headlight and motor are off, then there is some reason other than the thermal protector (i.e. pulled plug) your vacuum is off.
To reset the thermal fuse:
. Unplug the vacuum cleaner
  1. Check for problem - over-filled bag, clog in hose, clogged filters, etc.
  2. Correct problem
  3. Locate "tripped" fuse - the small white button located on the bottom of the back side of the main body (roughly one inch to the right of the left wheel)
  4. Using a pencil, paper clip or other pointed object, push the reset button in
  5. Plug vacuum cleaner in and resume use"
Mar 08, 2015 | Riccar 8955 Upright Vacuum
I need a small plastic part which controls air pressure in the Nilfisk Alto attix Vacuum cleaner
Fixya does not sell replacement air pressure controllers and cannot recommend sources.
Jul 24, 2017 | Nilfisk Vacuums
I need the catch that holds the accessories lid down on a nilfisk x300 vacuum cleaner. it also forms part of the handle. Where can i get the part and what is it called
Hi there SmartAlec from NelsonVacuums.com.au here. The part for your nilfisk x300 is called an accessory lid lock part number 1470184500. I am a nilfisk dealer so i can help you in getting this part. I think it is about $12. I will list it for you on my website NelsonVacuums.com.au or send me an email and i can organise an over the phone transaction. Hope this helps.
Happy Vacuuming! :)
Aug 18, 2009 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Nilfisk c120 vacuum - no power
Mar 15, 2009 | Vacuums
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
I am looking for a nilfisk c120.2 pressure hose replacement i seem to have looked everywhere
need to be more specific,is it click an clean tube with tornado nozzel ,or 15m drain&tube cleaner.
Aug 28, 2008 | Nilfisk Vacuums
Vacuums Logo
59 people viewed this question
Top Nilfisk Vacuums Experts
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Andrew Taylor
Andrew Taylor
Are you a Nilfisk Vacuum Expert? Answer questions, earn points and help others
