Question about Home
How do you clear a blocked toilet - Home
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Thanks for sharing and downloading <a rel='nofollow' href="">Gamestop holiday hours</a>
Posted on May 01, 2017
Toilet stays full will not drain?
the lever is broken or the valve is stuck
open the tank and check what is blocking the water from flowing into the pipe when the lever is pressed
Apr 16, 2014 | Home
At the moment we have a saniflo plus but the whole system has blocked but the pipes are clear what should we do next
If the toilet doesn't flush but the rest of the plumbing works fine you may need to buy a closet auger to clear the toilet stoppage, they cost around $20 and do wonders much better then plungers
Jun 25, 2010 | Elite Saniflo SaniCompact- SaniCompact One...
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Water won't go down the bowl..Seems to flush fine except water wont go down...Nothing is obstructing is not clogged
If water won't go down, you have an obstruction. It might be up inside the trap of the toilet. Use a closet auger to try to remove it. If the toilet trap is clear, you either have a clogged stack or vent.
Dec 02, 2009 | Toto Home
My saniflow toilet is blocked and a plumber has told me i need a new motor. where can i get this and how much are they?
If you hear it making noise the motor isnt blown, but it could be clogged.
A quick an easy fix is by filling a 5 gallon bucket with hot water (or warm water) and slowly pouring it into the bowl. The warm water breaks the particles up further, and will help flush the unit out. Make sure you run the water alot after its cleared out (to flush the debris). You can do that by turning on the shower or sink (if connected). If you dont have a shower or sink just keep flushing the toilet.
Sep 03, 2009 | Saniflo Sanicompact 48 Toilet With Pump,...
Toilet problem
sometimes it's a simple as the paper you use.double and tripple ply will do this to an older toilet everytime.I'm a plumber for 20 yrs,this is always the problem.
Jul 15, 2009 | Plumbing
Toilet problem
Your getting build-up in your pipes thats why it clears and then comes back, Make sure that you or anyone is not putting hair or anything else besides toilet paper in it and try flusing a big bottle of chlorox bealce down it 2 times a week and also use a very good drain opener.
Jul 15, 2009 | Style & Co DP Style FT006-S08 Tanneli FT...
ToTo S300 spray very weak
Poor some clr in the washer bottleand block the nozzles as you run the clr through. they will clear up, but don't leave the clr on your paint or in the washer bottle. Rinse everything out and off.
Jul 10, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
My saniflow saniplus has stopped pumping water i think- the toilet and bath has filled up with waste water. i have taken the top off the saniflo and blades are working fine but they keep going because the...
We had that problem but the unit was built in and I could not get at it, the outlet pipe sounds like it is blocked, I cleared mine by connecting a pipe from the cold tap to the outlet pipe and flushing.
May 11, 2009 | Saniflo & Saniplus& Macerator Pump
I have a toto toilet. After flushing it is taking a very long time to fill up.
Make sure that the fill valve doesn't have debris caught inside near the valve needle. Also the tube that attaches onto the flush valve can become clogged near the fill valve as well. Remove the hose and then take a needle and try and clear the outlet. Blow through the tube to insure that it's not blocked as well.
Mar 07, 2009 | Toto CST414M-11 Aquia Dual Flush Elongated...
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
