Question about Bosch Drills
My Bosch rotary hammer only go on reverse - Bosch Drills
  • 2712 Answers
SOURCE: hammer drills and rotary hammers comparison
Basically yes. Lower power units are usually titled as "hammer drills." Higher power units, usually labeled "rotary hammers," tend to be larger and provide bigger impact forces. But there are a few differences that are worth knowing: The rotary hammer usually have a chisel only feature, for light chiseling and masonry removal. Rotary hammers also have specially designed chucks that only accept bits specifically designed to fit their chuck. The special chuck on a rotary hammer helps hold the drill bit and prevents it from slipping during use.
Posted on Aug 27, 2008
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
comax
  • 154 Answers
SOURCE: i have a bosch rotary hammer 11245evs and it was
They are filled with a special grease that comes from Bosch. It sounds like the impact bolt or the striker pin in the unit are not moving the way they should. These are the pieces that work together to create the hitting action. About all that can be done now is the unit has to be dismantled to get those to pieces moving again. Bosch makes what they call service packs for all thier hammers. They have all the o-rings and grease to get your hammer working again. A Bosch service center can supply you with the kit. Ask for P/N 1617000225, or they can take care of it for you.
Hope this helps
Posted on Apr 16, 2009
jimboz4
  • 305 Answers
SOURCE: looking to add oil to rotary hammer Bosch / Bulldog
the oil seal is broken, remove front cover at the chuck end of the drill, and replace the seal,
Posted on Jul 22, 2009
comax
  • 154 Answers
SOURCE: Bosch rotary hammer (model # 11230EVS) drill will not rotate
There is a clutch in the main spur wheel of the unit. These sometime begin to slip, on rare occasions they will slip to the point where the drill will not rotate. If you are interested the part number for this clutch is 1617000817.
Posted on Aug 06, 2009
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
How to put together Bosch 11235evs rotary hammer
here you go the whole parts list.... good luck http://www.ereplacementparts.com/bosch-11235evs-0611235739-rotary-hammer-parts-c-128_1376_1380.html
Jun 05, 2015 | Bosch Drills
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do you change the brushes on a bosch 36 v-li
Once you have removed the 4 screws holding the gearbox to the main body take off the right hand half of the housing leaving the left half on the work bench. Unscrew the 2 screws that hold the brush holders down and remove the old brushes and refit with new ones. Rebuild in reverse.
Oct 24, 2012 | Rotary Bosch 11536vsr 36v Sds+ Roto Hammer...
Hammer function does not work on Bosch 11224vsr
Its usually a problem with the selector knob... depress the button fully and turn it passed the selection markings and pull it out to remove it
Aug 29, 2012 | Bosch Factory - Reconditioned 7/8" SDS -...
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
Looking for an owners manual for a 5/8 bosch rotary hammer
If you go to Boschtools.com you will find the manual you are looking for. They are all on the web site.
Jan 19, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Need \rnBosch Rotary Hammer Manual 11255VSR
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000001/r01003v-1.pdf
here you go!
Jan 15, 2010 | Bosch SDS-plus BULLDOG Xtreme Rotary...
Bosch 11247 Hammer drill works in drill mode but in hammer mode it spins as drill but does not hammer. Also how can I remove drive shaft from housing?
Usually replacing the o-rings on the piston, striker and Impact bolt will solve any hammering issues. That is considering there is no damage to the mechanical parts in the hammer mechanism.
Feb 27, 2009 | Bosch 11247 Factory Reconditioned 1 -...
Drills Logo
114 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
