Question about Cub Cadet Garden
Mowing deck locks when engaged to mow so what could be the reason ?
Its a Cub Cadet LT 1050.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Is something under the deck locked up against the blades?
Posted on May 02, 2017
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 376 Answers
SOURCE: 46 inch cub cadet mowing deck
Go to... http://www.partstree.com/parts/ Click on the Cub Cadet logo then enter your model number. All the diagrams are there.
Posted on Jun 11, 2009
mindreader
  • 578 Answers
SOURCE: I have a 2005 Cub Cadet Series 1000 LT 1050 with
Sounds like the drive belt has been thrown off of the drive pulley.
It is fairly simple to identify the drive belt. - it is the one that is connected directly to the pulley coming donw from the motor... and it travles over a tensioner pulley (that you control with the clutch) and then over the large pulley that is mounted over the transmission.
Check to be sure that the belt is ON the pulley... and not broken..
-Jim
Posted on Oct 17, 2009
SOURCE: i have a cub cadet 1050 hydrostatic. when i was
Your drive belt is broke or it jumped the pully
Posted on Oct 29, 2009
My 25 horse power cub cadet mower starts and runs great until you try to mow with it and it has no power. At half speed it mows fair but in heavy grass no power. Any help app. Bill
be sure the battery is fully charged. be sure the blades are sharp. be sure there is no grass or string or wire wrapped around the spindles under the deck. be sure it is firing on both cylinders . be sure the belt is in good shape .
Jul 05, 2017 | Cub Cadet Garden
LTX 1040. Why doesn't blade lever move when engaging blades?
How's the cable?... when you pull back on the lever, do you have tension?
Oct 11, 2015 | Cub Cadet Garden
How can I disable the reverse stop switch on a cub cadet Lt 1050
so you can mow in reverse ???
should be a switch in or around the transmission that could be unplugged. not saying you should, but could
this is if you have a hydro... a manual trans is different
Apr 26, 2015 | Cub Cadet Garden
Was mowing-blades just quit turning-pto will not engage
Belt has broken, or jumped off the pulley, or jumped off the belt tensioner. Look at your deck and go from there. You may have to remove your deck to get to the belts under there cvers but you will see your problem.
Jul 03, 2011 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
