SOURCE: 1999 Dodge Grand Caravan horn and Cruise control
I recently had the same issue, but my airbag warning lights also turned on. If this is the case, it might be the clockspring. There is a recall on clocksprings for Caravans 1998 - 2000 I believe. I got it replaced for free in the dealership. Enter your VIN in this site and it will tell you if you are covered in the free replacement warranty.
http://www.chrysler.com/webselfservice/chrysler/index.jsp?screenName=recall&country=us&emailUrl=goToEmailForm%28%27R%27%29
Hope this helps.
Sonny
SOURCE: Is a 2000 Dodge Grand Caravan fuel filler neck usable in a 1999?
yes it will swap and you have to remove it from the bottom of the van remove the screw/clips from inside the filler door and then from underneth disconect the filler tube ti tank and the vent hose to the tank i belive there is a bracket also holding the filler tube to the body with one bolt then it snakes out of the va r insalating is just reverse
SOURCE: 1999 Dodge Caravan with a code 23. What does that
OBD-II Trouble Code Technical Description
A P0020-023 code refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module). That consists of an oil control valve (OCV), also called a solenoid valve and other components. Basically the check engine light and associated P0020-023 trouble code means that the voltage in the circuit has fallen below a set limit for a specific amount of time (varies by make/model/engine). Bank 2 is the side of the engine that doesn't contain cylinder #1.
Causes…
A code P0020-023 may mean that one or more of the following has happened:
Possible Solutions
Some recommended troubleshooting and repair steps are:
SOURCE: 1999 dodge caravan fuse box map/diagram
Under the hood. Under the cover for the fuse box is a map of locations
