When i try to boot from DVD it says cheking media fail?
    Sergeant:
  • 111 Answers
Not all DVDs are bootable.
Posted on May 01, 2017
My pc wont boot. All i get is " reboot and select proper boot device or insert boot media in selected boot device and press a key"
This can happen if you have non-bootable media in the default boot device (i.e., you have a CD in the CD/DVD drive and that drive is listed as the default boot device in your system's BIOS). More often (on newer systems), a failed hard drive will also produce this message.
If you have bootable media (the Windows install CD is one example), you should try to boot to it and see if you can read your hard drive.
Jan 20, 2014 | Computers & Internet
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* CD/DVD optical device
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
0F00:136C IDE device failed:blank media or no media is present in optical drive
read failure of the CD\DVD drive. If you were running diagnostics and have no readable media in the drive, that is a NORMAL result.
If you have readable media in the drive, try reseating the drive and try to read again. If the media is not a factory burned CD, try a factory burned one.
See if you can boot to an Windows CD.
If all the above fail, then likely a drive failure, replace the drive
http://cgi.ebay.com/Dell-Inspiron-E1505-6400-6000-E1705-DVD-RW-DVDRW-Drive-/170505381668?pt=PCC_Drives_Storage_Internal&hash=item27b2e9a724#ht_3121wt_1137
Sep 25, 2010 | Dell Inspiron 6000 Notebook
Hp proliant server dl380 g3. gettting PXE-E61:Media test failure, check cable how to fix it..
Your server tries to "boot" from several sources:
* floppy-disk
* CD/DVD
* disk-drive
* network (if you have a "boot-server" somewhere on your network)
So, if your computer FAILS to boot from the first 3 devices, above, it will try the 4th, namely via your network-adapter.
When your computer finds that its network-adapter is *NOT* connected via an Ethernet cable to a boot-server, it reports "check cable" and "test of the media has failed".
So, why did your server *NOT* boot from the 3rd device, namely your disk-drive? Solve that problem, and the 4th device (the "network-boot") will not be tried, and the error-messages will not appear.
Aug 27, 2010 | Computers & Internet
It has a probelm rebooting and it says "media check failed , check cable
Your computer tries to "boot" from various source:
* floppy-disk
* CD/DVD
* disk-drive
* network (if your computer is connected via an Ethernet cable to a network that has a "boot-server" on it).
Thus, your computer has _NOT_ found anything "bootable" on the floppy-disk, in the CD/DVD drive, on the disk-drive, and so it tries to check if you have a network-connection to a boot-server.
So, the "big" question is why did your computer *NOT* boot from the disk-drive? Either you told it not to make such an attempt, or the disk-drive is "dead", i.e., not responding to requests to boot from it, or there is no electrical power to the disk-drive, so that it cannot reaply to the "boot-request".
Take your computer to a qualified computer-technician; it's probable that your disk-drive has "failed".
Jun 09, 2010 | MSI Wind U100-016US Laptop
My E drive is not working. how can i fix it.
Have you tried cleaning the laser assembly? If your OS still sees the drive then it may just be having trouble reading.
Try this
First try to boot from your xp cd. If it fails to boot from the cd then your drive is screwed. If it does boot from the XP cd then ONLY try the following
Click Start.
Click Run.
The Run dialogue box appears.
Type devmgmt.msc in the run dialogue box and click OK.
Click on the plus sign next to DVD/CD ROM Drives.
Locate your DVD/CD ROM drive in the list of devices.
Verify the type of drive in your computer and that the type of media you are using is supported by the drive. Use the table below to determine the supported media types.
DVD+/-RW Read CD or DVD media, write DVD+RW, DVD-RW, DVD+R, DVD-R, CD-R, CD-RW media.
CD-RW/DVD Combination Drive To read CD or DVD media, and write CD media.
DVD-ROM Drive To read CD or DVD media.
CD-RW Drive To read and write CD media.
CD-ROM DRIVE To read CD media.
Try cd drive now before trying the next step
Click the Start button, right-click My Computer, and click Manage.
The Computer Management window appears.
Click Device Manager.
Click the (+) plus IDE controllers section.
Double-click the appropriate IDE channel.
The IDE Channel Properties window appears.
Under the Advanced Settings tab, verify that the transfer mode is set to DMA if available.
Click the OK button to save the change. At this point, you may need to restart for the change to become active.
Check to see if the drive will work in safe mode. I it still does not work Update the firmware for the optical drive.
Click the Start button, click Run.
In the Open box, type Regedit, and then click OK.
Click the plus sign (+) next to HKEY_LOCAL_MACHINE.
When you click the plus sign (+) next to a folder, it will expand displaying the folders it contains in the left-hand pane of the Registry Editor. When a folder is highlighted, its contents will be displayed in the right-hand pane of the Registry Editor.
Click the plus sign (+) next to SYSTEM.
Click the plus sign (+) next to CurrentControlSet.
Click the plus sign (+) next to Control.
Click the plus sign (+) next to Class.
Click {4D36E965-E325-11CE-BFC1-08002BE10318}.
On the right side of the window, click UpperFilters.
Click Edit on the menu bar.
Click Delete, and then click OK.
On the right side of the window, click LowerFilters.
Click File, and then click Exit.
Restart the computer normally.
If all these steps fail then you will need to replace your drive.
Thank you.
Sep 17, 2009 | HP Pavilion dv9000z Notebook
I/o error. press any key to restart
The jumper on the hard drive may be on the wrong pins for this motherboard. If it's on MA try CS and vice-versa.
May 17, 2009 | Intel Computers & Internet
System corrupted and would not boot during installation of sp 1
Try cheking the Bios Settings Before Runing the Recovery CD.
Is your computer's bios set up to boot from the cd rom or hard drive first?
If so, try changeing the setting so the computer boots from the CD Rom.
Mar 22, 2009 | Toshiba Satellite A215-S7437 Notebook
Computers & Internet Logo
David Payne
David Payne
