Question about Pentair Pool & Spa
Just replaced a 12 yo Pentair 400K BTU pool heater with a new Raypak 336K BTU heater. It now takes >2x longer to heat my pool. I did not expect this when going from 400 to 336 btu. Please advise.
  • Greg Murch
    Greg Murch May 03, 2017
    Hi Michael. It was a Minimax NT.
  • Michael Prior
    Michael Prior May 04, 2017
    First off the BTU out-put of the NT is rated higher but the NT is also a force draft type burner. The Raypak is an atmospheric type burner.
    A burner, either force draft or induced draft will have a more consistent BTU out-put. If it seems very different in out-put you may want to check the header by-pass built into the Raypak. It is thermal activated and may be throwing off the temp-rise of the heater.
    Visited the website for 60 consecutive days.
  • 121 Answers
What model Pentair? Master Temp.........?
Posted on May 03, 2017
  • 22 Answers
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Posted on Dec 21, 2008
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
  • 21 Answers
SOURCE: I have a 2003 400K btu Pentair MiniMax NT pool
have you tried the thermister?
Posted on Oct 02, 2009
Testimonial: "THANKS FOR YOUR ADVICE!!! Checking the thermister, I found that one of the white wires had broken....spliced ends together and heater now functions!"
  • 64 Answers
SOURCE: H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1: how do i fix the AO code on my hayward heater?...
AO will apply to your blower, blower tubing, or blower vacuum switch. You need to check these items.
Posted on May 20, 2010
  • 31 Answers
SOURCE: I have a Pentair 40,000 BTU pool and spa heater.
The heater is trying to light but cannot. Either the igniter is broken or you are not getting any gas to the igniter. Check to make sure your gas valves are on.
Posted on Apr 18, 2011
Raypack pool heater trouble codes
check flame sensor if wired 120 volt see wiring on inside of panel
Jun 22, 2014 | Raypak Rp2100 Digital 336k Btu Propane...
CLK code will not heAT
Not sure about your specific heater, but if the heat won't go on, it could be the water pressure sensor or one of the temperature sensors.
May 05, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
check gas pressure then replace highlimit rollout switch if ok replace hi limits in header
May 04, 2012 | Raypak Rp2100 Digital 336k Btu Propane...
We just installed a new Raypak 400k BTU cupro nickel NG heater. It's connected to a Jandy PDA controller. If I set the temperature above 86 on the PDA, the heater will cut off at 86. If I take the heater...
The heater need to be set to max heat and then let the controler control it. Which ever is set the lowest will stop the heater. Good luck and let me know how you do.
Apr 02, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Not keeping the pool heated. it heats it up but then cannot hold the heat. What is the warranty on these units?
warranty is two years. if it's still in warranty, pentair should send a tech out to repair it.
Feb 02, 2010 | Sta Rite Maxi Therm 400k Btu Propane...
My raypak rp2100 electronic seems to light the pilot light but then it takes a while to light the gas and when it does it shoots flames out the top of the heater. I'm thinking its the gas valve or the...
It is probably something much more simple than that...Turn it on and stand back until it finally ignites, then look, using a mirror, at the burner tray from below. You will probably find a lot of the tubes, especially those near the pilot area, are not working or are burning bright orange. If that is the case, something, probably spiders, are blocking the gas from getting into the tubes. That will cause the big burst at ignition as the gas builds up for a bit before it finally reaches the pilot area.
Aug 13, 2009 | Raypak Rp2100 Digital 336k Btu Propane...
Pool heater getting only half of 24v
bad transformer or wiring if new and 120 volts see inside front cover for wiring if old replace transformer
Apr 28, 2009 | Raypak Pool Heater Covers for Teledyne &...
Pool & Spa Logo
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
