Question about Rotary Tools & Hardware - Others
I need a collet set for a Pro Source Rotary tool Model#S1J-HD-10
4 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Kawasaki Rotary Tool is missing the square collet nut
I am working on getting a website for this company, but you can try Alltradetools.com and see if they have anything, they distribute them.
Posted on Oct 03, 2009
SOURCE: Can't find replacement collets/locknut for PowerSmith rotary tool
Hello Bob, I recently saw your post about the Power Smith PS2103. I have this same tool, and have never been able to use it because the collets don't fit the bits.
I was looking at it recently - I have the owner's manual - and although there is no web address, there IS a toll free help line. Here is the number - 888-552-8665
I called the number - got their voice mail, left a message, but they have NOT returned my call!
The only outlet that MAY carry this brand is Zellers, but I haven't been there yet.
Good Luck!
Bob (in Canada)
takemoff@shaw.ca
Posted on Dec 07, 2009
SOURCE: I have a Durabuilt rotary tool model S1J-FE2-10
I have the same problem with mine. The collet nut that came with it is too big. It wont screw down to hold the collet. I am searching for a new nut.
Posted on Dec 21, 2009
How do I change to the smaller chuck size?
In your kit, you will find some collets to hold the smaller bits. Unscrew the cap, insert the collet and replace the cap. Inset the smaller bit and tighten the cap. The collets have slots cut into them so they can tighten down on the bit.
May 24, 2015 | Dremel 7700-1/15 7.2v Cordless Multi Pro...
Rotary tool Model S1J-AJ2-10
Check the power coming in. Apply an ohm meter across the plug to see if you have continuity through the motor. We really need more information.
Oct 31, 2013 | Tools & Hardware - Others
Instruction manual for pro.source#EDG110 Model; S1J-AJ4-10
Hi Kathy,
I have searched extensively for the manual for this grinder but unfortunately haven't been able to find it.
The product is made in China and then badged by various companies.
This is a manual for a Dremel grinder tool which may be of some use to you:
https://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D//t10/0000000/r00600v-1.pdf
There should be a button or option which allows you to cancel the $12 charge for this service if you wish.
Sorry I can't be of more help.
Nov 21, 2011 | Tools & Hardware - Others
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
Mar 14, 2011 | Craftsman Single Speed Rotary Tool
How do you attach "multipurpose cutting kit model 565" to the dremel multipro model 395?
Remove the collet nut and collet then unscrew the sealing cap (black plastic ring), this has the same thread as the inner of the multi kit tool, so just screw on the tool then replace the collet and nut
Sep 14, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Oct 02, 2009 | kawasaki 840168 Green 150 Pc Rotary Tool...
I have a Durabuilt rotary tool model S1J-FE2-10 that I can't seem to get to hold a bit. The directions say to hold the spindle lock button down and put the bit into the collet and tighten. I doesn't hold...
User Error! There are different diameter collets. I bet you are using a larger diameter bore collet than the bit outside diameter. Collet can be purchased at any hardware store. To remove unscrew nut, remove collet and replace with proper diameter.
Aug 28, 2009 | Tools & Hardware - Others
Craftsman rotary tool doesn't lock down on the bits.
the collet is either the wrong size for the shaft on the attachment or is missing alltogether
Jul 04, 2009 | Dremel Variable - Speed Multipro Rotary...
Motor runs, collet doesn't turn
get a hot glue gun and go to your local hardware store and buy a piece of tubing to fit the collet shaft fill with hot glue and press it on the shaft.
Jun 19, 2009 | Dremel Variable - Speed Multipro Rotary...
Good Luck!
Bob (in Canada)
takemoff@shaw.ca
Jun 10, 2009 | Tools & Hardware - Others
Tools & Hardware - Others Logo
128 people viewed this question
Top Rotary Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
raysaw
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
