Question about Lincoln Welding Tools
My meg 175 lincoln was welding fine , i shut welding down ,and a week later the machine does not come on
    New Friend:
  • 15 Answers
Hello Mark,
There are many things that can cause a machine to not come on. Start from the basics and work to the hard. Check and make sure there is power to the receptacle, then power in at the machine where the main power connects to the power block inside. You'll also need to check the power switch and see if power is getting that far. If all that checks out ok, then you have a more serious problem that is not likely to be repaired through a few short messages. Also, do not attempt to diagnose anything unless you are comfortable and knowledgeable enough to work with live electricity.
Good luck,
Ryan
Posted on May 03, 2017
I have a Lincoln pro mig 175 keeps throwing the
Look for a piece of weld wire touching the feed or spool and grounding to the cabinet.
Sep 01, 2014 | Welding Tools
I have a Lincoln Pro Core 100 wire feed welding machine; it is (5) years old. I use the machine often. A year ago I built a 5' X 20" barbeque pit out of pipe and attached a 2' X 2' X 4' smoker to it...
Hi:
There is nothing wrong with your machine. The Pro-core100 is a 20% duty cycle machine; meaning: that will work for 2 straight minutes of welding and then needs 8 minutes to cool down.
Just allow the machine to cool down, turn it off and start again after the 8 minute cooling process.
If this was useful to you please vote. Thanks.
Mar 29, 2011 | Lincoln Electric Welding Tools
I am looking for an instruction manual for a Lincoln 175 HD weldpac #11082
Hi and welcome to FixYa, I am Kelly. Here is the 48 page user's manual for a 175 HD.
http://content.lincolnelectric.com//pdfs/products/navigator/im/IM825.pdf
The HD stands for Home Depot.
This certainly appears to be the manual your looking for. If not respond here and I will look again.
Thanks for choosing FixYa,
Kelly
Jan 11, 2011 | Lincoln Electric K1170 AC-225 Stick Welder
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
I have a Lincoln Weld Pak 100 that was working fine. I shut down the machine though and when I came back to it about 5 hours later the wire feed motor wouldn't turn anymore. Has anybody else had the same...
Check the voltage at the wire feed motor when the trigger is pulled.
I had a Weld Pak 100 that with 0 volts at the wire feed motor, and the problem wound up being that 2 of the big power (stud) diodes were shorted.
Feb 26, 2010 | Welding Tools
Welding machine wont start
there might be a low oil shut down switch that is open, look for it and jump it out, and then try to start it
Nov 15, 2009 | Lincoln Welding Tools
Lincoln MIG welder: Gas not shutting off.
gas regulator needs checking or replacing!
Or you can use GASLESS WIRE!
Jul 24, 2009 | Welding Tools
Welding machine stops working after a few minutes of welding.
there is probley nothing wrong its called duty cycle.which means that if you are welding long periods or welding at max amps the welder will kickout to cool down.Look on your unit for the tag that tells imformation about your unit.It will show something like 30% duty cycle so that means you can weld 3 minutes at full power before the unit shuts down.
Mar 25, 2009 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welding Tools Logo
770 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
